Ridgeman |
06-04-2012 06:56 PM |
Ignition switch problem
Can I just replace the mechanical part of my ignition switch without having to replace my current key and FOB? They are not cheap to replace.
Been having a problem with key not shutting off acc power when I remove it. If I wiggle it around I can get it to shut off most of the time. But the other day I couldn't get it to shut off with the key removed. Radio power stays on and the beeper goes off until I close the door. I can shut the radio off manually but the power door locks won't work because the truck computer still thinks I have left the key in the ignition. So I have to manually lock the doors. Next time I used the truck I was able to wiggle it to turn off the acc power. But I figure it is just a matter of time before it gets worse and maybe even gets to the stage where i have problems starting or shutting off the engine.
Though maybe replacing the mechanical end of the ignition might fix it. Any one had this problem or know of a fix?
