How To: Front shock install
great post!! this saved me sometime trying to figure out what size sockets and wrench that i was going to need. Only a couple things i did different was i used a universal joint style adapter on the end on my 15mm to take the bracket nuts off worked good for me. Great job again Rock crawler
If the shaft is spinning you will need to use a 3/8 (or 9mm) wrench on the top part and the other wrench to loosen the nut.
Do you have any air tools to use?
rockcrawler, Great write up (I copied it back in Feb). Probably a dumb question, but are you having to jack up the truck at all when you change them?
I finally did all four today! It went pretty well, I didn't have to remove any batteries or airbox or tubes. I didn't jack it up at all and it was fine. It would have went faster, but I kept stopping for football breaks. ;-) I installed KYB Monomax and I really like the improved ride and control. Thanks RockCrawler!!
Thanks for the write up. I finally got all 4 of my shocks replaced. The rear I had done before and are very easy. The front kept giving me issues that were minor but I finally got them done after about 4 hours. Top nut was the hardest part to get off. I used vice grips on the shaft through the wheel well to get it to stop turning. Oh 30 minutes of the time I spent looking for the rubber spacer that I dropped into the engine block and it didn't fall through.
But its done....thanks again.
