help finding body panels
My truck has a bad case of rust along the bottom and I'm going to replace all the bad panels. I was able to find cab corners and rear wheel well replacement planels, but I can't find the rocker panels for a mega cab.
The only thing I can find is the quad cab rocker panels with Dodge you have to buy the complete cab side. From rockers to the roof, a little over kill, if someone could help I'd appericated it
Rocker panels
Did you notice inner rockers had tape over drain holes on both sides ? Mine did , strange not a random piece on tape torn off and stuck on there but , same size over every drain hole . Look at this before replacing outer skins , this maybe the cause of failure , I remove tail lights and rinse out bed sides after every winter season to remove salt spray also . I know this doesn't repair your issues but may help new panels to last a bit longer
Syndicate
14
02-26-2007 12:46 PM
aaronedwards82
10-01-2006 10:20 PM
Shaders 24v
16
04-20-2004 02:23 PM
