Hello & VIN history please?
Old Dec 16, 2007 | 11:18 PM
PsychoRallye's Avatar
Hi guys-
Looking into buying a 03 2500 Quad 4X4 5.9 HO 6SP ST. Didn't know if someone with the ability could give me the original options listing from the VIN, and the maintenance history (assuming pretty safely this is all in the computer somewhere!). I have the carfax and Autocheck reports, just not the dealer history (serviced when, where, what, etc) and the original window sticker.
Edit: Forgot the VIN. Here you go.. 3D7KU28C03G760765
Also, when I go to pick it up (I have the downpayment in on it already), is there anything I should look for on the test drive or on a visual inspection that is a show-stopper and I should walk away from the deal on ? I've heard about the door seals and the shimmy issues, neither of which sound like they'd be show stoppers.. any others?
Any help is appreciated... so thanks in advance!
Old Dec 16, 2007 | 11:28 PM
vzdude's Avatar
DTR's 'Go to Guy'
Looks pretty typical to me. Other than = Rear axle assembly? U-joints not too much later - looks like it had a vibration or noise concern. Keep the radio down on the test drive! Looks like a nicely equiped truck.
May 21, 2004 68128 - JAMES O'NEAL CHRYSLER PLYMOUTH
16500511 - Universal joints, single piece 036584 19,291 Miles 2004061 WARRANTY
April 12, 2004 68128 - JAMES O'NEAL CHRYSLER PLYMOUTH
03300100 - Axle assembly, rear 036047 17,559 Miles 2004043 WARRANTY
March 15, 2004 68128 - JAMES O'NEAL CHRYSLER PLYMOUTH
23133600 - Frame, seat 035666 15,065 Miles 2004041 WARRANTY
January 20, 2004 60045 - JUSTIN DODGE CHRYSLER JEEP LLC
08C02182 - Recall C02 002715 9,020 Miles 2004033 RECALL REPAIR
December 7, 2002 42689 - STOKES CHRYSLER CO
95900040 - Road Ready-Basic Prep PREPNV 0 Miles 2002122 PREPARATION
APAS Monotone Paint BAZS 136 Amp Alternator BRTS Anti-Lock 4-Wheel Disc Brakes
CGDS Front Height Adjust Shoulder Belts CGWS Next Generation Front Air Bags** CKJS Black Vinyl Floor Covering
CSPS Passenger Assist Handle CUES Rear Underseat Compartment Storage DH1S Man Shift-on-the-Fly Transfer Case
DJQS 5,200# Front Axle GACS Tinted Glass Windows GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror HAAS Air Conditioning HGBS Dash Liner Insulation
I86S Route 86 - CSX, Lawrenceville, GA JAYS Instrument Cluster w/Tach JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers JJAS Cigar Lighter JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet LMAS Halogen Headlamps LPES Cargo Lamp
MBFS Bright Rear Bumper MCLS Gray Upper Fascia MCTS Bright Front Bumper
MDAS Front License Plate Bracket MHAS Black Windshield Moldings MURS Dodge Badge
MUSS 4X4 Badge MWDS Removable Tailgate w/Caliper Latches MXBS Front Air Dam
NFVS 35 Gallon Fuel Tank NMCS Heavy Duty Engine Cooling QS2S Bright Silver Metallic Clear Coat
RBBS AM/FM Cass Radio w/Changer Control RCDS 4 Speakers SBES Power Steering
SCFS 4-Spoke Steering Wheel SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar TBBS Full Size Spare Tire TBMS Tire Carrier Winch
WD2S 17X7.5 Steel Styled Wheels WF1S 17 Steel Spare Wheel XBSS Pickup Box
XFUS Trailer Tow w/4-Pin Connector Wiring YAAS Build To U S Market Specifications 1AAS U.S. Dealer Retail
166S Zone 66-Orlando 5I4S Four Wheel Drive (4WD)/(4X4) 5ZFS 8 FT. Cargo Box
5ZKS Quad Cab 5ZMS 2500 GVW 594S Vehicle Order Tracking
6USS Label - U.S. Specifications 601S Alabama State Code 901S Alabama State Code
Optional Equipment
Code Description Code Description Code Description
*P9 Cloth 40/20/40 Split Bench Seat -DV Dark Slate Gray AHC Trailer Tow Group
AJK Convenience Group A50P 5.9L TD HO Eng(ETH)/6Spd M/T NV5600 BCQP 750 Amp Maintenance Free Battery
CBEP 40/20/40 Split Bench Seat CFMP Rear Folding Seat DEE 6-Speed HD Manual Transmission
DMF 4.10 Axle Ratio DRQP 11.50 Rear Axle DSA Anti-Spin Differential Rear Axle
ETH 5.9L HO Cummins Turbo Diesel Engine GPD Folding Trailer Tow Mirrors HGFP Floor Tunnel Insulation
K1XP JET BLACK - Molding - Bodyside K17 Bodyside Molding MFD Bright Grille
MXCP Front Air Close Out Panel NAA Federal Emissions NHKP Engine Block Heater
NHMP Speed Control NZCP Current Generation Eng Controller PS2A Bright Silver Metallic Clear Coat
RDDP Fixed Long Mast Antenna SUAP Tilt Steering Column TWE LT245/70R17E BSW On/Off Rd Tires
TZGP BF Goodrich Brand Tires WMJP Center Hub XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness XJL Front Hood Protection Shield XZAP Speed Control Type
YHBA 8 Additional Gallons of Diesel Fuel ZEJP Spring - Left Front ZGRP Spring - Left Rear
ZTHP Spring - Right Front ZVRP Spring - Right Rear Z7CP GVW Rating - 9000#
0BOA DESCRIPTION NOT AVAILABLE 0BRA DESCRIPTION NOT AVAILABLE 0B1A FAM: DR TRACKING: 20912T10 MY:2003
2BA Customer Preferred Package 2BA 2TAA Customer Preferred Package 2TA 3VCA Customer Preferred Discount
4KZP 4X4 Tracking 5A6P Waterbase Paint 6FD Paint Order Code
Special Equipment
No Special Equipment Available
Dealer Installed Equipment
No Dealer Installed Equipment Available
Old Dec 16, 2007 | 11:51 PM
Wow, talk about quick! Thanks so much!
I suppose that means the truck has the 410 rear, great for towing not so great for mileage. Do you guys recommend leaving in the 410 rear or is the 373 worth putting in for mileage purposes ? I do plan on towing a decent amount, but not usually more than 12000 lbs... though some of it can be in hilly country. Most of the time I'll only be towing a measly 8000 lbs.
Thanks again! And yep, I think no radio and some feeling & listening is in order to see if that vibe issue is still present... but I can only assume it's not, since the last dealer/warranty item was back in 04...
Old Dec 17, 2007 | 01:26 PM
Hounddog's Avatar
If towing 8k to 12k once a week or more you'll like 4.10s.
Old Dec 17, 2007 | 01:31 PM
deerefarm06's Avatar
IMHO 4.10's are overkill unless your towing really heavy ALL the time. I have 3.73's and ive done quite a bit of towing with my truck and im very happy with them. As far as mpgs goes with the 4.10's I cant help you much. The best ive seen with my truck is 21mpg, im averageing about 17-18
Old Dec 17, 2007 | 01:57 PM
Rednecktastic's Avatar
Yeah 4.10s are what you want if you go to a bigger tire or tow a lot... Or both I guess.
Old Dec 17, 2007 | 02:02 PM
Justwannabeme's Avatar
DTR Mom
Wink hmmmmmm, flood damage? check under the rear carpet at the door..
o wow, we have 17s with the 4.10 diesel 4x4 off road just for towing, but we get 22 mpg on the flats and thruway.. about 12 mpg towing the 12,000 boat
about 19 through the hills and twisty roads. haven't done a thing to it- stock.
lucky I guess
heidi
Old Dec 17, 2007 | 02:09 PM
Hounddog's Avatar
Fill out your sig/profile of your truck like the rest of us.Sure that boat weighs 12k and 22 mpg hiway non loaded?
Bowser50
Jul 26, 2009 07:22 AM
GasganoFJ60
Dec 17, 2008 08:30 AM
Shovelhead
Aug 13, 2007 11:47 PM
upjeeper
Jun 16, 2007 04:03 PM
Intercooler
Jun 3, 2005 09:41 AM
