Fuel/Water Separator?
Old 06-09-2017, 11:06 PM
danalex's Avatar
Probably a stupid question, but here goes...
Stock fuel/water separator.
How often should I flip-the-lever to drain from the stock filter--just in case there's some water? I generally drain and change the filter at each oil change (or AT LEAST every other change...). Is that draining (at filter change) good enough?
Background to my question: I'm debating on Glacier's combined MK2 filter with fuel/water separator kit. But if the stock fuel filter (serving as water separator) is just fine, I'll just go with the MK2 filter set-up by itself.
(I know I'm probably overthinking this one...but humor me please.)
Thanks!
Old 06-24-2017, 01:31 PM
Shorts's Avatar
Fuel up at quality stations and the standard filter change interval is fine for draining.
The GDP 2mic between the stock can and pump is good insurance.
Old 06-24-2017, 08:05 PM
Jeff in TD's Avatar
Yeah. I used to drain some fuel into a glass container every thousand or two miles, but I never found water, so now I drain every few thousand (unless I have to fuel someplace sketchy).
After a buddy had to replace injectors at low miles I put the GDP 2'micron filter kit on, which uses the stock setup as a prefilter/water separator.
For stock power applications, that seems to be a cost effective and easy to install way to get better filtration and injector protection.
I generally change both every 10k.
ouchman
03-27-2006 06:22 PM
ii caan
01-28-2006 07:49 PM
chailey
07-29-2005 01:51 PM
67HotRod
06-13-2005 08:01 AM
Hoss
14
06-16-2003 08:51 AM
Quick Reply: Fuel/Water Separator?
