Front end/ ball joint question
Recently, while driving on semi-rough roads, I can feel a "clunking"(not so tight) feeling from the front end. I can feel the clunking(for lack of better term) through the steering wheel and through the go pedal. It feels like there is something loose under there. Also my steering doesnt feel like it used too. I have been under there and as far as I can tell, everything is tight.
Ive been reading alot about bad ball joints and did some searching. Could this be my ball joints going bad? I have 25K on the truck.
Is there a way I can test or check to see if I have bad ball joints?
Jack up the truck and get the tire about 1.5" off the ground and take a 24" pry bar and put it under the tire and try to lift the tire upward with it. If the tire/wheel assembly moves up and down more than a millimeter or so then you have worn ball joints. When I replaced mine on my 04.5 you could move the assembly 1/4" up and down.
Some others may have some better imput.
Jamie
PS make sure you put 3.5 gorillas on tightening the track bar. It's the bar angled from the frame to the (i think) passenger side of the axle. Keeps the axle from shifting side to side. I put the cheater bar on my 04.5 when I had the lift kit on it and had to tighten the CRAP out of it to get it to quit popping.
Jamie
Jamie
Jamie
72dart
06-19-2012 10:42 PM
Wulzcat
12-19-2009 05:15 PM
wcbcruzer
22
04-30-2008 06:58 PM
FDC
07-16-2007 12:51 PM
Treangen
05-07-2007 03:10 PM
