factory fog lights
Old 01-08-2012, 01:45 PM
kerry.king's Avatar
factory fog lights
My truck does not have the factory fogs in the bumper. I'm wondering if the wiring and harness is hidden there somewhere. If it is, any suggestions on what lights to use and how to mount them?
Old 01-08-2012, 02:22 PM
justen920's Avatar
I have the same issue. If you get under the driver's side and look up you will see the wiring harness above where the light goes. All you need to do is buy the lights, harness and switch. I have been looking on craigslist for a cheaper version, but if you find one please share. Good luck.
Old 01-08-2012, 03:55 PM
larrybartlett's Avatar
I just bought the kit from my dealer, just under $200, install was easy. I hooked mine up so they will run with both brights and dims
Old 01-08-2012, 06:32 PM
Top's Younger Twin
Scotty's Avatar
How did you do that? I have been thinking about doing this for awhile, never got to it though.
Thanks
Old 01-08-2012, 10:44 PM
justen920's Avatar
Geno's garage sells the wires to be able to run both at the same time. I believe it is called Bright Box. $200 is a little steep for me, especially when I want an after market bumper some day.
Old 01-09-2012, 04:25 PM
ltlace1's Avatar
Just bought the factory fog light kit off e bay for $105! great deal
Old 01-09-2012, 04:34 PM
justen920's Avatar
That is a great deal.
Old 01-09-2012, 05:59 PM
Totallyrad's Avatar
Thanks
Scotty, on my 04 instead of using the low beam power wire for the trigger wire, I used the parking lights. I accessed the wire in the same location, behind the driver's side headlight, a few inches behind the socket. Doing it this way I didn't need anything special since the circuit comes with a relay and as long as your parking lights have power you're good to go.
Old 01-10-2012, 07:49 PM
wellmax's Avatar
i have an 05 model and do have the factory fog lights.
headlights are so poor that if i did not have fog lights, i could not see very well at all,
I sure wish i knew how to get them to stay on when i switch to brights.
most times i drive with the dims, because the fog lights is about all you have.
headlights must have been an after thought on our trucks.
Old 01-10-2012, 10:06 PM
kerry.king's Avatar
Just browsing thru the lmc catalog. They have aftermarket ones with an l.e.d. halo ring for 119 for both lights. Or buy the stock replacements for 79.95 a piece. Think I'm gonna get the l.e.d. ones.
Old 01-11-2012, 06:27 PM
kerry.king's Avatar
found the plug on the driver side. what about the passenger side though? is there a harness that runs from there to the light on the d side?
Old 01-11-2012, 06:31 PM
06RAM2500's Avatar
One harness, runs one side to the other. Instructions say to have the dealer enable them. Don't because they shut off when you have your headlights on high beam.
Old 01-11-2012, 06:33 PM
06RAM2500's Avatar
If you upgraded the stereo in your truck, your about 6 more screws and two pieces of plastic short of being able to get to the headlamp switch easier.
Old 01-12-2012, 08:55 AM
kerry.king's Avatar
I haven't messed with the stereo. The factory one is good for me.
Plugging into the harness there won't power them? Should I run myown power supply and switch? Like I would if adding kcs? Or does the stock harness run them off the headlight switch?
Old 01-13-2012, 07:39 AM
dezeldog's Avatar
I wired my the same way and that way I can have the fogs on with just the parking lights. This is helpfull in real dense fog or a heavy snow storm where the headlights would be reflecting back in your eyes. HTH
Jim
Quick Reply: factory fog lights
