Exhaust noise?
Any time I get above 2,000rpms the roar is to much. I bought this truck used so I'm not sure what was done other than the obvious stainless tip at the rear of the exhaust and the exhaust brake. It still has the resonator and muffler, intake is all stock. The stainless tip on the exhaust has a rolled edge that wouldn't cause all the noise though would it?
You're sure it still has the cat behind the turbo? I took mine off for a while and I couldn't not stand the drone inside the cab! [yuk]
Cat is still there only thing I can see is the SS tip that is different. What kind of welds are there at the ends of the cat? Maybe they gutted it?
Originally Posted by Tree DR
(Post 1355938)
Actually, easiest way to tell is do you smell diesel? It's very stong without a cat. If not, then it's probably not gutted.
Diesel smell is strong. What's the best route to go to kill the drone?
(Post 1356426)
I spoke to this guy... http://www.dpsdirect.com/ ...when I was having the same issue (I didn't realize the cat played such a big role in the drone) and he said on these newer Cummins the drone is VERY pronounced without the cat. He said he leaves them on because they only contribute about 50 degrees to EGT and flow very well. He said most of the heat and restriction comes from the stock muffler. I put mine back on and he was right. I went with a 30" Magnaflow and I'm very happy. Almost as quite as stock, which I like, but much better performance and lower EGTs. The other option is to put a 54" (I think that's the size) Donaldson muffler under the truck, you have plenty of room. This is actually a muffler for a semi... http://www.donaldson.com/en/exhaust/...ent/index.html That should get rid of the drone AND serve as your muffler as well. |
I second the donaldson idea, but be careful, there was some discussion a while back on here about the differences in the units. some of the donaldsons dont flow as good as others. But you can find this info on thier website
Kevin |
I got my 40" Nelson from the local Cummins shop for $67 CDN. The body is longer than the stock one but it's 4" straight through, no baffles at all.
Trying to find a place to do the install which is a little work with the offsets being different. The guy I went to yesterday goes to a shop where they make exhaust systems for trucks, they can bend 4" pipe, your normal muffler shop can't do pipe that big. Word on here is it'll sound great if you leave the cat in place. |
Well there is one advantage to haveing a drone. Because it starts after 2000rpm. You keep it below 2k which means better mpg.
Well there has to be a few loose cats around here some where. Probably could find one if I looked in enough barns. |
(Post 1357798)
Originally Posted by Fisherguy
(Post 1356651)
Originally Posted by TurboTed
(Post 1357834)
If the cat was cleaned, you may want to go with the 52" Nelson. Get the free flowing muffler. No drone at all.:cool:
From what I've heard from more than a few people, removing the cat will give you the droan.
Ask me Tuesday after I get mine back... |
(Post 1357913)
