electrical swings at startup
Old Dec 14, 2008 | 11:19 PM
Morology's Avatar
Really interesting problem lately. I had the issue with the yellow wire on the starter and has been fixed. Yesterday it finally got cold here in Seattle and when I went out to start the truck I waited for the "glow-Plug" light to extinguish and then started the truck. All appearsd normal until all of the lights dim and the voltage meter drops to 10 volts. It stays like that for a few seconds and then returns to normal (around 13-14 volts when running). Then it repeated the same for a couple of minutes until the truck warmed up and then everything was great. Got to the store, turned the truck off and when I returned a few minutes later the same thing happened again. It happens every time i start the truck now but does not affect the driveability or the starting of the truck. I have turned on and off all of the electrical (stereo, lights, fan) I can with no change. Any help would be appreciated
Old Dec 14, 2008 | 11:37 PM
Checkmate's Avatar
Grid Heater. Normal in cold weather. Once truck warms up, it should stop.
NO glow plugs.
Old Dec 15, 2008 | 12:15 AM
Sevir's Avatar
yup, grid heater is cycling. Turn off your radio and headlight (if you have them on) it will help just a tad, but it will still be there. Plugging the truck in at night also keeps the grid heater from coming as much.
Old Dec 15, 2008 | 03:13 PM
zuki_dan's Avatar
Also if you drive it above 15 mph it will also stop cycling the heaters.
rockcrawler304
16
Jan 27, 2009 03:21 PM
juice
Dec 29, 2005 07:12 PM
jrs_dodge_diesel
Nov 18, 2005 09:21 AM
gkainz
Nov 9, 2003 07:26 PM
silver_goat
Nov 24, 2002 07:47 AM
