Electric Window Problem
OK all my windows work from the driver's master switch. None of the passenger windows work from their respective door. I just replaced the master switch as I figured the lockout switch was hosed. No fixee. before I replace all of the other switches can anyone think of anywhere or anything in the wiring that might be fried?
Thanks [duhhh] Hondo |
Fuse? Maybe....
I cannot find any blown fuses in the fuse block. Any anywhere else? Anyplace where all the wiring comes together.
Hondo |
Did you check the passenger window lock out button located on the driver's side???
^ what I was thinking too. I have to play with mine to make it work from the other switches. Wait - ! ! - I re-read your post. Already replaced it huh? Here are some wiring diagrams. Hopefully you can find it. Looks like the OR/LB wire would be the one to trace. Changes colors for some reason near the right rear switch, but I would bet it is near the drivers side since it affects all 3 other switches.
