DRW to SRW
Old Feb 7, 2010 | 10:55 PM
quicksilvr's Avatar
DRW to SRW
Can it be done? I don't own one, but I've been thinking about buying one b/c they are easy to find with a 6 speed. Those bed sides look like they're just stuck on over a regular bed, maybe I'm just dreaming but I figured I'd ask. I'm guessing axles are the same and it would just need different wheels.
Thanks, Eric
Old Feb 8, 2010 | 01:33 AM
quicksilvr's Avatar
Well I stayed up late and read a lot, looks like it can be done. I'd love to hear from people that have done it.
I did discover there is notched section in the bed after removal of the fenders, I wonder if a Bushwacker extenda flare would cover this plus provide extended coverage for the rear wheel sticking out farther. I think if it did, I would add a spacer and flare to the front and the truck would look pretty mean. I'm thinking the only labor intensive part would be filling the holes left behind from the fenders.
Old Feb 8, 2010 | 01:36 AM
quicksilvr's Avatar
Old Feb 8, 2010 | 04:37 AM
nwflyoda's Avatar
the rear axle is different between the drw and srw trucks. i believe the drw axle is about 4"s wider.
Old Feb 8, 2010 | 02:53 PM
quicksilvr's Avatar
The rear housing is the same, the rear has a spacer on the hub after the rotor, if you remove it one will have source SRW axle shafts. See picture above it's not that big of a difference.
Old Feb 8, 2010 | 03:06 PM
ripping r's Avatar
if you can find some one close. that want's to make theres a dually you could swap. i would like to make mine a dually. but have not found anyone close to do swap with.
Old Feb 8, 2010 | 10:51 PM
nwflyoda's Avatar
i believe you'll also have to move the rotor from the back of the hub to the front. i believe the drw rotors have the studs pressed through them into the hubs and the srw don't.
i'm in the same boat here. i'd like to convert mine to one as well but there isn't anyone close that wants to do the swap. so i'm just content w/ keeping mine a srw.
Old Feb 9, 2010 | 01:36 AM
quicksilvr's Avatar
Well if I wind up with a DRW truck in the next few months I'll be wanting to swap. The rotors are in the same location on both setups no modification is necessary to bolt on a single, the wheel will just stick out a bit compared to the front, see photo above.
Old Feb 9, 2010 | 05:11 AM
nwflyoda's Avatar
i can't view the photos. i thought that to replace/turn the rear rotors on the drw trucks you had to remove the hub to do so. i guess i may be wrong. i know the brake caliper and axle shaft and wheel bearings are different part numbers for that of a srw truck.
Old Jun 21, 2010 | 12:08 AM
6WheelDiesel's Avatar
I would swap in a heartbeat!
MikeRP
79
Nov 21, 2016 10:19 PM
lawdog800
19
Mar 31, 2011 09:26 AM
89dieselkong
Apr 5, 2009 05:20 PM
Roger Portmann
Dec 10, 2008 09:20 AM
dragginlx
15
Mar 9, 2007 11:32 AM
