door seal leaking? 2003 weatherstripping?
i was wondering if anyone has issues with the door seal on the drivers side making noise? which seal is it the top one or the lower one? i thought the newer models had this issue fixed so is it interchangeable?
Not sure about the noise, but the new improved version is interchangable. I did it on my 05, I think it was as cheap as $13 per side.
Have the same issue on the highway with wind noise.what is the part #.
If you look as you open the door the pillar rubs on the weather stip I had it replaced under a tsb or recall on my 03 gasser
I also have this rub as the door is opened. My local dealer suggested that the weatherstrip would not be covered. Any information regarding a TSB and part number would be appreciated.
I replaced mine with the 07 weatherstrip. 2 pieces on each side. works better.
Not sure on the part number, just go ask the dealership for weather stripping.
Yup, I had my drivers side door wear a couple of holes in my weather stripping. I just put up with it.
Scott |
Originally Posted by Dr.Dizzle
(Post 2685629)
Dr. D, maybe this is what you are looking for... http://dodgeram.info/tsb/2005/23-049-05.htm You can go here and check out some other TSBs as well... http://dodgeram.info/tsb/index.html Hope that helps .. |
Thanks! I will print this and present it to the dealer.
This was arecall on my 05. Dealer replaced it with new design at no cost to me.
so which seal is it the top one or the one around the door? thanks
around the door
