Does anyone know the control arm bolts torque spec?
I took off my lift and put the factory arms back on and torqued them to the other lift kits bolt spec but i have a knocking around sound coming from the frint end and looks like one of the bolts is moving around anyone have the torque spec for me?
1 Attachment(s)
Looks like 120 ft-lbs. (see attached)
cool thank you
No problem.
I re-read that page and the lower arm with the cam adjusting bolt should be tightened down to 160 ft-lbs. So... Upper Arm: 120 ft-lbs Lower Arm: 160 ft-lbs PS - I recently uninstalled my 4" lift kit also. Truck rides smoother, handles better, and getting better mpg probably due to combination of being lower to ground and smaller tires. |
what lift did you have? i went from a 6 inch tuff country coil spacer to a 3 inch kore suspension, thank you very much for the specs tho i def did not tighten them enough
Tighten down as tight as possible. Same goes for the trac bar. If they are not. Then you will get a popping or binding noise.
Originally Posted by itr.#1446
(Post 2029649)
Make sure the pitman arm nut is tightened to spec!!! Mine ended up losening up after a few miles when I first installed my kit. [duhhh] |
