Dodge dashes!
[verymad]Ok, I know this has been beat to death, but what are you guys doing with your cracked dashes? I found the dash ABS/plastic "cover", but it looks like crap. I will not put a carpet cover on.............. unless I can find some fuzzy dice to match it.:rolleyes: What are you guys doing? TIA
I have the "Carpet" cover dash mat and no cracked dash. I also use a sun shade when it is parked.
yeah, you have an 06 not an 03 and with your cover I doubt you'll ever have my problem. I'm looking for a response from someone in my boat, thanks.
No cracks but I do have a Ultimat molded dash mat cover. Fits great and also cuts down on the glare.
MikeyB |
(Post 2233139)
Ok Guys, Dodge CS called me back today and started a "case #", I went to my local dealer and they took a bunch of pictures and said they will be contacting me w/ when to drop off my truck. That's all, no more info, but it looks promising. I will keep you posted!
Nice. What do you use to clean it? I hear that armoral makes dashes crack.
I use F2001... |
Originally Posted by madhat
(Post 2233953)
I use F2001... |
What...?
So keep it in the garage during the day, and only drive it at night then? Just keep it covered with papers, maps, dust, etc... |
I got it... let's put 100 spf on that crap...
my dash is in perfect shape- but then again i always use the window shade in the summer months and always use protectant 303 to clean the dash with
My 03 just cracked this summer. I know a couple other guys with 03-04 trucks with dashes that have cracked.
No dash problem here. But I keep the 'Ultimat' on mine and use a sun shade when parked and try to park in shade whenever possible. I am also guessing the mat helps protect the stereo/other electronics from excessive heat. The Texas Summer Sun is relentless. Without protection on the dash it will eventually succomb to the rays.[director]
(Post 2233953)
I use F2001... |
Originally Posted by tcr
(Post 2234568)
No, I was wrong, I used F21 by Turtle wax. Says it's all kind of UV protective, but the dealer said the problem was the products cover up the plastic and insulate the heat into the dash causing the cracking........who knows????[yuk]
MikeyB |
