Diesel concentrate
Old Jan 20, 2009 | 10:54 PM
racemydodge's Avatar
Thumbs up Diesel concentrate
Has anyone used the Amsoil diesel concentrate? If so how does it compare to
power service and what seems to be the most liked brand from anyones experience? Any other products that i could try?
Thanks
Old Jan 21, 2009 | 07:02 AM
Fuel additives
what fuel additives works the best for the cummins? ofor are they all pretty much the same quality?
Old Jan 21, 2009 | 07:38 AM
Hounddog's Avatar
I don't think anyone can give a fair answer to that.I've tried several different brands.Can't tell a difference in any of them much less any difference if its straight diesel or has a additive.Would like to see some REAL world testing showing that ANY of the additives really do anything other then lighten your wallet.
Old Jan 21, 2009 | 07:45 AM
Thanks for the reply. I used some of them and could tell a bit of difference
thwas another thread where peops are using 3 cyc.oil is that correct? is it safe?
dodchall70's Avatar
I use a mixture of Power Service (gray bottle)and Howes Meaner Cleaner injector cleaner. It does seem to make my truck run a little smoother and not quite as noisy. But there again that could just be in my head
Old Jan 21, 2009 | 07:51 AM
what is mean kleaner? is't it the same as power service? or is it just a straight injector cleaner.
Old Jan 21, 2009 | 07:58 AM
Hounddog's Avatar
2 stroke ASHLESS oil is what you are refering to.Howes Meaner Cleaner is another brand.Howes products hve been around a long time.Find it at truck stops.I did have a friend with a 03 and a stall/hesitation issue.Had a bad FCA.He could add a big slug of a number of differant additives and it would be ok for that one tank of fuel.If not used it idle poor,stalled just of idle etc.The only BIG slug of additiive that did NOTING for it was LUCAS.Had no affect.Powerservice,Howes,Ashless 2 stroke oil and Marvel Mystery oil all had a affect.But Lucas did not.Even with almost a entire bottle it did nothing.
Old Jan 21, 2009 | 08:07 AM
ok.. so 2 stroke ashless oil ! So that does what to the fuel adds more lubricity?
This is my 1st diesel 04.5 and from what igather its a good one.(roasting mustangs and dusting duramax's) It seems to me this motor is like the old goat on the farm it will eat anything you put in the fuel tank.
Old Jan 21, 2009 | 08:17 AM
At this point you could add gasoline and the 2stroke oil and probably get the same results. Well gotta go earn my keep! Say yes to Michgan! that was a slogan here. ya right its flippin cold !
thanks for the replys
Old Jan 21, 2009 | 08:29 AM
Hounddog's Avatar
These new diesels are not ole goats that can burn anything.That was 12 valve days.These new ones can ruin injectors and burn pistons pretty darn easy.You'll roast many a other car/diesl out there but remember these key words.You play,you pay!
ChrisJohnson
Oct 15, 2009 07:52 AM
sallyman1
Mar 29, 2008 09:47 PM
JoeDiesel
Mar 18, 2003 06:24 PM
