didnt disconnect battery, electrical issues
Well, I know this seems to be a very amateur mistake, and it certainly is. We had an exhaust leak on an 06 pickup and went about putting in new gaskets. While we were there we went ahead and ordered the delete pipes for the exhaust because we’d wanted a straight pipe for a while. We got the manifold and turbo out and replaced the pipes on the exhaust system and went to put the manifold and turbo back in. We got it situated in there and had it bolted on with two bolts and started to put the others in. My brother was torquing them down and the ratchet, well the extension and socket, came in contact with the alternator and the exhaust manifold. Now, as the title says, the batteries were still connected. I know this isn’t a safe practice but we’ve gotten in a bad habit of not undoing them. Anyhow, the socket stuck to the alternator about welded it on. I jumped off and grabbed the closest thing I could find and wacked the thing off but not before the passenger side battery sparked real bad and the wire from the alternator to the battery snapped off. It had gotten to hot. Not sure what the wire is called. I figured we would have a bigger issue on our hands than just that wire and I was correct. We finished up the manifold and put the downpipe elbow back on and fixed that wire. Cranked the pickup, which started fine, but the cluster lit up with ABS light and the parking brake light as well as the engine light (engine light was on before and after this predicament we put the code reader on, all codes were the same as they were before the work was done). We went to drive it and the speedometer doesn’t work. It sounds good though haha. But in all seriousness I would like to resolve this issue as soon as I can. I’m not electrical savvy by all means but I can try my best. Checked all the fuses in the fuse box and all were good. Went to the store and grabbed new 4 gauge wire and made a new cable. Put it on, still didn’t fix it. Speedo is still gone and the lights on the cluster are still lit up. Please feel free to offer help.
Thanks
Thanks
I don't have much to add...You said you checked all fuses, but did you check them with a test light?...If codes came back after clearing them, what were they?...Sorry I'm not much help on this......Ben
I checked them with the volt meter set on the sound setting where it beeps when it detects a full circuit. I’m not at home to look at the codes again but I think they came back. I’m stumped on this. I’ve read a bit about a certain fuse labeled spare, number 30 I believe, is actually for the abs system. The thread said that if the abs system is altered that the speedo will be affected too. I just don’t know where the problem is. Thanks for your response. I’d really like to get the thing up and going again.
Alright. I’ll have to check on Sunday. Do you know where I can find a diagram or schematic? I don’t have an fsm. Any other ideas?
Received 1,637 Likes
it’s not letting me look at the website at the moment so I’m downloading the app. I won’t be able to check on the pickup till Sunday afternoon though. I’ll try and look at the wiring tomorrow. Thanks for you help and I’ll definitely update y’all as to what’s going on
Well we've just been driving it without a speedometer since then, hate to leave a thread open-ended but we haven't fixed it yet. Its my brothers pickup and we replaced the speedo sensor but that didn't do anything, not that I thought it would. Still trying but we've still got nothing. Thinking ECM though.
Mike M
08-11-2006 10:03 AM
termite
08-20-2005 11:37 PM
