Denso AC Compressor?
Old May 12, 2016 | 12:09 PM
67HotRod's Avatar
I have replaced EVERY part of my AC system and appears the second 4 Season AC compressor is failing again. Vacuum, oil, pressures all good. Only getting 70 degrees out of the vents. Was told the Denso compressors hold up allot better?? I can hear the current compressor knocking inside. And yes my fan clutch is working and 12+ volts to the compressor.
This is on my 06' 3500.
Thanks
67 HotRod
Old May 12, 2016 | 04:38 PM
67HotRod's Avatar
I took some gauge readings and showing 50 psi on the low side and 200 on the high side.
Drier partially clogged?
Thanks
67HotRod
Trumm
Mar 21, 2011 09:48 AM
VADSLRAM
Dec 10, 2009 10:06 AM
rammike
May 19, 2007 07:29 PM
banshee
Apr 25, 2006 11:32 AM
russ300h
Apr 10, 2006 06:15 AM
