Delayed Accessory Power
Has anyone figured out how to enable this yet?
Its available on the 1500 and Dakota (some of those are standard). aka Retained Accessory Power This is what it's called when you turn the key off and the radio/windows still work for a few minutes. |
It's a dealer enabled option. While your there get the high idle enabled.
Say it ain't so Joe!
There's no workaround? Smarty, OBDII... |
Bully Dog Triple Dog.
Unless you have a programmer you gotta go to the dealer. Just had mine done, max a dealer will do id 10 minutes.
Originally Posted by Fisherguy
(Post 1416169)
Originally Posted by stezlaki
(Post 1416685)
BullyDog Triple dog does more than 10 minutes.............I want to say you can go to 30 minutes............I can't remember for sure, but I do remember it is more the 10 minutes the dealer can/will do.
Really? How often do you sit in the truck without it running for more than 10 minutes?
I'll play with my BDTD when I get it, it's sitting at Canada Customs still... :( |
(Post 1417209)
What I don't understand is how BD found a way to set it for a longer delay time then what a Dodge dealer can. I have mine set at the 10 min max time that the dealers can enable if for :(
Originally Posted by DBLR
(Post 1417748)
My 'Business Link' dealer will set it for 60- 90 mins , reset tc for better lockup, Manual high idle, what ever you want!Manchester ,NH
My dealer just said no on 04
Originally Posted by ptgarcia
(Post 1417837)
Can? Or want? That is the question. Maybe the techs are instructed to do 10 minute max.
My dealer said they set it to 10 minutes. I changed the radio and took the neg battery lead off and now it's at 45 seconds. It's not a feature I use often but man... Can it revert back to something after losing power? Or did they not set it correctly?
