Death Wobble
Old Jan 9, 2009 | 04:28 PM
Diamond266's Avatar
Death Wobble
I'm sure this has been a topic more then once,But what really is the cause,,,,Tires,shocks,ball joints,tie rods,I just replace all four tires,got on the highway,hit a pot hole and it was all over,couldn't belive the wobbled..it was all over place ,,,I never felt anything like this in my life,,,ok spoke with dealer they said that its common,and suggested that I change the steering shock,so I did and it seemed like t worked ,,, but its back,,,front end looks tight and I only have 70,000 on an 04,, so what way do I go,,, help needed...... Thank you
Old Jan 9, 2009 | 04:31 PM
dslpwr81's Avatar
Check out the thread right below yours. Upgraded steering. READ the Whole thing. lol
Old Jan 9, 2009 | 05:04 PM
Ace's Avatar
Ace
Originally Posted by Diamond266
...I just replace all four tires...
Usually a suddenly appearing problem is directly related to the last thing you touched. I'd air them up and go from there. Alignment next. Mine was caused by worn ball joints.
Old Jan 9, 2009 | 05:29 PM
jamesbfishin's Avatar
Didn't you just change the track bar bushings as well? That would be the first thing replaced and with something other than new factory units.
Also fill out a signature so the folk here can see what you have.
Old Jan 9, 2009 | 05:32 PM
yellowhemi's Avatar
What tires are you running? The BFG's seem to be suceptible to death wobble.
Old Jan 9, 2009 | 05:34 PM
315's in particular
Old Jan 9, 2009 | 05:38 PM
John_P's Avatar
Diamond266:
Here is a link to the thread on the "Death Wobble" that DTR Member dslpwr81
was talking about:
https://www.dieseltruckresource.com/...d.php?t=220996
John_P
Old Jan 9, 2009 | 05:47 PM
BroncoAZ's Avatar
Originally Posted by jamesbfishin
315's in particular
This is likely because they are tall, wide, and not the proper E rated tires for the truck.
Old Jan 9, 2009 | 05:50 PM
John_P's Avatar
Diamond266:
Here is another link to a thread on "Death Wobble" we had going back in 2007:
https://www.dieseltruckresource.com/....php?p=1729455
John_P
Old Jan 9, 2009 | 07:34 PM
Diamond266's Avatar
Goofball Club member #18 Sorry to upset you ,when I have some extra time I will fill out all the paper work for you
As far as My truck it's 04,2500 Slt
All stock.70,000 miles
New tire's Dueler A/T REVO
Burgundy
And thanks Guys for the Help
Old Jan 9, 2009 | 08:46 PM
Goofball Club member #18 Sorry to upset you next time I have some extra time I fill out all the paper work for you
Burgundy
Didn't upset me at all, just trying to help out and knowing what kind of rig you have and what might be in it helps us to help you.... Sorry if I came off as being a little cranky, been sick all week.
Old Jan 9, 2009 | 08:53 PM
mitternocht's Avatar
Interesting that your dealer admits it is common. Other dealers say they have never heard of it on a Dodge, lol. I’ve never had it and don’t want any part of it.
I wonder what is going to happen when a large percentage of these trucks really get some miles on them?
Did you get an alignment too? Guys are saying that generous caster helps prevent DW (5-7 deg) rather than the specified 4.5 I believe. Maybe your caster was generous and they set it back to stock? If not I’d say something is up with those tires? They did give you E rated tires?
Old Jan 9, 2009 | 09:04 PM
dodgestang's Avatar
FWIW when I had the wobble start on almost any pothole over 50 MPH on my 10,000 mile 97 2500 that was on 35 14.5 16.5 at the time the solution was a Moog replacement track bar and it never happened again in 80k miles even after I went to 38s.
Old Jan 9, 2009 | 11:38 PM
Diamond266's Avatar
You bet James,,, I'm feeling like **** myself ,, and now this stupid wobble ,I'm kind of leaning to the bushings being worn out even though, I don't see any play..front end looks tight ,
They are E-rated and I had them Road forced balanced ,but no alignment,if it don't snow here tomorrow I'll double check the frount end ,,,,, Thanks
Old Jan 10, 2009 | 07:38 AM
Ace's Avatar
Ace
I've come to the conclusion that the root cause of DW in these particular trucks is a fundamentally deficient front suspension and steering design. Any number of secondary causes (tires, alignment, joints, lifts, yada, yada) either alone or in concert may come into play to set up the vibratory harmonic that sets it off. The best approach is simply good maintenance in terms of inflation pressure, high-quality e-rated or better tires, more frequent aligments and early replacement of wear parts.
725Gus
Mar 6, 2014 09:49 AM
Trooperthorn
Nov 30, 2010 12:06 AM
Jezzhuntin
Apr 11, 2007 04:52 PM
smokindodge1996
Feb 13, 2004 08:54 PM
moneypit
Sep 23, 2003 06:06 PM
