Dealer visit next Tuesday
Old Jan 25, 2007 | 01:21 PM
ssandlin's Avatar
Going to take the truck in next week for the following, and was wondering if anyone else has done the same and what the fix was.
1. Rear window leaks from the top on the passenger side. Not a bad leak, but enough to leave a trail of rain water spots on the inside of the glass.
2. Rear window makes a "creaking" sound on the driver's side when the truck frame flexes.
3. I have lost channels 120, 121, 122 and 123 on the Sirius radio. Called Sirius and all they can do is re-send the activation signal, which did not work.
Any input is appreciated. Thanks,
Old Jan 25, 2007 | 07:27 PM
DiEseLjunKy's Avatar
I've heard the creaking sound. So it's the rear window? I thought it was my toolbox. It's not that bad. I can live with it.
Old Jan 26, 2007 | 07:39 AM
ssandlin's Avatar
Yep, it's the rear window. I've been living with it for awhile too, but since I'm going in for the radio problem, I'll have them take a look at it while the truck is there.
Old Jan 26, 2007 | 08:02 AM
DynoDynamicsNE's Avatar
I have a noise that appears to be coming from the front passenger door. I'm thinking it's the plastic door panel, but I haven't checked it.
If your window is leaking, it may also be the culprit making the noise, but I bet it's the plastic panels causing it. I used to work at a Chrysler/Plymouth dealership in the '80s, and I was always hunting squeaks. It always turned out to be the plastic panels inside the car. After leaving the dealership, I hadn't had the privilege of driving a Chrysler product until I bought my truck, so I'm not sure if they were able to correct the problems they had back then.
Let me know what you find when you get done at the dealership.
Old Jan 26, 2007 | 10:09 AM
ssandlin's Avatar
Thanks for the reply. I had not thought of the plastic panels. I can say that the truck did not make this noise when new, only the last few months.
garymcbroom
Dec 8, 2008 08:28 AM
herb
Jul 7, 2007 04:42 PM
subspd
16
Oct 25, 2006 05:55 PM
NWDave
Nov 19, 2002 10:59 PM
Nov 6, 2002 05:20 AM
