Centrematics are amazing!!!
I have not been able to keep my back tires balanced until I finally stopped listening to other peoples opinions on centrematics and give them a try for myself. Everybody I talked to said they were junk and would not work. I refused to run stick on weights and I wanted something that I would not have to jack with when I rotate the tires.
I started with beat on wheel weights which would get pushed off by the over sized tires I'm running on stock dually wheels. So then I tried to dynamically balance the tires using airsoft bb's. That worked great for the front tires, but I soon realized that it only made things worse out back (worse than no weights at all). After a ton of different attempts with different materials and different weights in the rear tires I decided it is near impossible to dynamic balance a set of duals with weight inside both tires (I don't know if it would work to put weight inside one tire per hub but I suspect it would). I'm now running a centrematic on each rear hub between the tires with not a single ounce of balancing weight anywhere and the ride is amazing compared to any of the previous attempts to balance the tires by two different tire shops.
I will be removing the bb's from the front tires and order a set of balancers for the front axle now. I'll be able to rotate the tires and never have to worry about getting the tires balanced. Plus I can swap tires myself now too with no vibrations.
My rear's are huge compared to your's. But mine are for 19.5" rims. You state that you have no weights on the rims? I left mine on, I wonder if I would be better off removing them? Won't let me post pics twice, see link.
https://www.dieseltruckresource.com/...d.php?t=285809
pic shows a 400-448 and I'm actually running a 400-409. I swapped to a bigger one because I knew I had the room, but I can't say that one works better than the other.
If you can keep wheel weights on I would leave them on. Mine would get thrown off inside of 500 miles.
Edit: I just noticed I spelled centramatic wrong.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
the balancing material in the outter ring adjusts itself to create the even balancing. it is always moving and self balancing from centrifigal force.
I have them front and rear and I love them.
Would not have a truck without them... Now tires do not wear out by out of balancing, the heat is much less and you will save the price of the centramatics in extended tire mileage alone.
Used to run them on my '71 Blazer with big tires back in the early 70's,, same problem couldn't keep tires balanced, this is back when big tires were just coming out, mine were Dick Cepek, rhino ture trac tires, I think they were called. You couldn't keep them balanced till I bought the balancing ring,,, it wasn't called Centrematics when I bought mine????
I can't remember what the name brand they were, but same looking design, you could here the bb's rolling around in the ring, inside the oil I think they had in the ring, could be wrong on that.
Wish I could remember the name, they kinda fell to the wayside, I guess, or at least I didn't see them anymore till now.
