c-code?
Old Feb 15, 2006 | 06:19 PM
txcoastie81's Avatar
c-code?
Just wondering if anyone can tell me what c-code 64 is? I'm having speedometer problems and I suspect maybe that has something to do with it. I am going to send my cluster out to a speedometer repair shop tommorow but I would like to know what that is before I do. Thanks
Old Feb 15, 2006 | 07:14 PM
RamWheelsBy4's Avatar
C0064 Generic Longitudinal Acceleration Sensor (Subfault)
That is all I can come up with, but sounds like it could be related to the problem.
Old Feb 18, 2006 | 10:33 AM
Thanks for the info!
Old Feb 18, 2006 | 08:13 PM
handymantim's Avatar
C codes come from the Instrument Cluster self-test which is initiated by holding down the trip odometer button and turning the ignition switch to on. All of the needles and lights move/flash in the instrument cluster and then the C codes are shown in the odometer window at the end.
C code 64 in the 2004 shop manual is "Driver door lock switch input circuit open." For some reason, this is a common code and probably doesn't mean anything.
If you want to get the other computer codes, you have to turn the ignition switch on/off/on/off/on and leave it on. Those codes will also be displayed in the odometer window.
Can you describe your speedometer problem?
Old Feb 18, 2006 | 08:34 PM
There are OBDII C Trouble Codes also. They are Chassis codes. P codes are power train. B codes are body. U codes are computer network. Not sure Chrysler or Dodge would display those codes though.
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
bkay
Mar 25, 2003 10:41 AM
