brake and abs lights on...
Old 12-16-2010, 01:46 PM
Sthil's Avatar
Question brake and abs lights on...
Alright before I pay for an ave tech $90 an hour does any one have any insight to what might be wrong? Thanks in advance.
Yesterday stared my truck brake and abs lights were on broke to work with out a problem everything seemed to work. Finished work drove home took truck to les schwab for a brake inspection they found nothing visually wrong. Just replaced hub assy and tie rod and U joints in front end about a month ago. plus I checked for any codes with my smarty and nothing came up. So any thoughts before I pay out for some guy to look at a computer.
Old 12-16-2010, 02:51 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Check fuses and brake lights first. You could have bad wheel speed sensor , did hub bearing come with new sensor? Check wiring to sensor especially by front calipers make sure wires are not damage or pinched. Also check fuse 30 labeled as spare it is use to power antilock module. Make sure it is not missing or open.
Old 12-16-2010, 03:09 PM
Sthil's Avatar
Ok I will check that this afternoon. And yes the new hub assys came with new abs sensors.
Old 12-17-2010, 11:39 AM
Sthil's Avatar
I have checked all fuses and connections, and wiring. Any other ideas before I pay a guy to plug a computer in and tell me whate wrong. And does any one know a place in my area that has the ability to read abs codes cheaper than $90 an hour?
Old 03-06-2011, 03:28 PM
jrdperformance's Avatar
same prob
I to just experienced your prob both lights came on but the only diff is that my speedo quit working so if ya have any help let me know!
Old 03-06-2011, 03:58 PM
CTD NUT's Avatar
If you lost the speedo, your particular problem is more than likely the rear ABS sensor in the diff. Either the wiring/connector has a continuity issue or the sensor is pooched and needs to be replaced.
Old 03-06-2011, 04:02 PM
num 30 15 amp fuse
I would start there it took care of my prob
Old 03-07-2011, 03:48 PM
TedT's Avatar
Check to make sure axle nuts are not loose. A loose nut would let the bearing wobble and ruin the speed sensor.
quadstar
11-20-2009 05:23 PM
polaris800sp
11-13-2008 05:35 PM
sssmaly
07-13-2007 12:57 PM
mr T
02-24-2007 06:42 AM
Quick Reply: brake and abs lights on...
