Bizzare Electrical...
Love the truck; purchased used last summer; now 170K miles. Laramie pkg w/leather heated seats. Starting to have bizarre electrical issues…
Tail lights: couple months ago noticed WATER in the lens (one compartment was completely full of water). Removed the lens and replaced the light-bar and all 6 bulbs. PROBLEM: For no apparent reason, sometimes when I use the turn-signals, the “arrow” lights on the dash behave like they are possessed! Flashing, blinking, sometimes both alternating, sometimes simultaneous. This happens maybe 30% of the time.
Tow-package lights: All lights on trailer worked fine. PROBLEM: Last weekend no “running lights”. Traced this to a blown 20amp fuse in engine compartment. Replace the fuse and all is fine.
Heated seat (driver): Chilly weather (mornings) arriving in South Texas. Tried the heated seat button on dash panel. It works fine after the temperature has risen during midday. PROBLEM: On cold morning, NOTHING. No lights, no butt-heat, nothing. Yet, I can come out to the truck at noon and hit the button and ta-dah…heat works. So, why not in the cold morning? Passenger seat side works fine. When I depress the driver-seat side, 50% of the time, the button blinks, then goes out. When working, both lights come on and stay on.
Heater-***** on panel: PROBLEM: fan **** and ‘air flow direction’ ****... 99% of the time, the ***** don’t light up. They did once that I can recall. No lights.
Rear passenger door lock: PROBLEM: No electronic working. Won’t pop up or pop down. ((thinking there might be a fault in driverdoor actuator))?
Heater: PROBLEM: For some reason, she won’t blow heat unless I force the “hot/cold” levers back and forth several times…sometimes takes 20-25 mins. When “heat” comes on, it’s NICE AND HOT…but until then, simply ambient temp air.
FINALLY: When starting up the truck (first thing in the morning) the instrument panel shows a “squiggly curvy” line symbol until the “red” light goes out. I can then turn off the key, then on again—no squiggly-curvy” line symbol…..what is that symbol?
Appreciate any thoughts!!
DTR Detective
Rear door is most likely broken wire in the loom where the door pivots, common problem.
Blinker issue most likely Multi-function switch (Blinker stalk). Common problem.
DTR Detective
I don't have heated seats so I can't say for sure, but I know my MFS caused all kinds of demonic possessions. Left blinker when Right engaged, doors lock and unlock while driving, wipers sometimes turned on when using a blinker.
danalex (12-01-2016)
GasganoFJ60
05-13-2008 01:59 PM
