Ball Joints going bad at 40,000
Thanks for all your reply's. At the moment, you can move the lowers a about quarter inch front to back. If you pull down on them there is some movement, but not bad. With the told tires on, I had noticed the steering seamed to wander a little more that it use to. With the new tires on, it seams to have gotten worst. Not as bad as the wander in the Ford F350 that I had before. I guess the ball joints may have something to do with it. I leaving for vacation today pulling my 5th wheel. We will see how it does on the trip. I will deal with this when I get back. Thanks for all the help. Anthony
You can add me to the ball joint group. Got a clicking noise in 4 wheel last week and took it to the dealer this morning. God bless extended warranty, upper and lower on both sides replaced with U-joint and axle seals. Oh yah 89,000 kms!
look closely at your new OEM joints for grease zerts. if no grease ports exits. keep your new joints pumped full of grease with a grease needle.
poke needle through rubber boot, then pump until grease comes out. keep same maintenance interval. every other oil change should do it. I'd pump it full after rough 4x4 sessions.
if you keep your joints full of grease, they will last next to forever.
what a load of manure!
HD components that come from factory with no grease zerts.
fact is our truck's joints carry a substantial load. not everyone's usage is the same.
dodge should give back option to reload grease.
is it a surprise.... most after market joints come with grease zerts.
when a joint goes dry... game over.
nope.. it's a usage thing. some folks drive over rougher roads than others. putting more cycles on joints.
if your joints are still good at 50k miles.... load em up with grease via a grease needle at regular intervals. every other oil change should be good. unless you go 4x4, then service is needed right afterwards.
don't wait until joints go dry... then it's too late.
There ae a couple of good writeups on the ball joint replacement. Check over on TDR too. That's where I found the best one.
You'll need a ball joint press. Also do the axle U-joints while you're there. They are not greaseable either. You can get heavy duty Spicer joints from Napa.
After you get done and get an alignment you can see if an offset joint would serve you better and "next time" get one with the right offset. I bought an adjustable BJ but didn't use it.
If you really want to do a nice job put the Dynatrac kit in at the same time. This gives you serviceable wheel bearings as well as hubs. Very nice! And it gets rid of the unit bearings that will eventually fail because they are not serviceable either.
Once all of this is done the truck will steer better and you can maintain it.
John
John
fatpete
15
Nov 28, 2010 10:13 PM
firebill1720
20
Mar 5, 2010 09:23 AM
jiggerman78
May 2, 2009 06:38 AM
