switch in battery box
Old 04-18-2015, 05:09 PM
realfast's Avatar
what is the switch in the bottom of the battery box?
Old 04-18-2015, 05:47 PM
verdesardog's Avatar
temperature sensor
Old 04-18-2015, 06:42 PM
realfast's Avatar
don't think so. it is some sort of pressure switch.
Old 04-18-2015, 08:48 PM
well you can think whatever you want but it is a temperature sensor
Old 04-18-2015, 08:51 PM
realfast's Avatar
well why does it appear to be activated by the weight of the battery?
Old 04-18-2015, 08:52 PM
Old 04-18-2015, 08:54 PM
do an online search for dodge cummins battery temp sensor, if you think it's a pressure switch you might learn something.
Old 04-19-2015, 08:12 AM
realfast's Avatar
thank you for the info. and you off beat humor. If you had first explained that it was a temp. sensor to reduce or stop the alt. from over charging. I would have bought it. But to say oh it is a temp sensor was minimal information. It sounded like so many here that know so little but come across with so much wrong info.
In the future when ask a question explain your answer thoroughly and you will shine among your peers and be known as very knowledgeable!
Old 04-19-2015, 09:17 AM
seafish's Avatar
Because it is under the battery?? lol
Old 04-19-2015, 09:20 AM
seafish's Avatar
Now if you were having problems with your battery overcharging, then you might need an additional explanation as to how the temp sensor influences charging rate, but you asked a simple question and got a simple answer…what is there to explain??
Old 04-19-2015, 08:44 PM
I answered your question as completely as you asked it......
Old 04-19-2015, 08:55 PM
Shorts's Avatar
Hey man, the info was correct. Just say 'thanks, my bad' and go on with it.
Personally the first time I saw that sensor I thought it looked like a pressure switch detonator for a land mine, that if I removed the battery it would blow up my truck. But, I removed the battery and my truck didn't blow up so, good to go.
Old 04-20-2015, 05:08 AM
Jeff in TD's Avatar
Yeah it's a temp sensor.
My truck once gave CEL and a code that battery temp sensor failed rationality check with the other temp sensors. Apparently it checkes intake temp against bat temp when engine is cold. Turns out there was a TSB to reflash and adjust the threshold where it trips the error code.
Old 04-20-2015, 07:54 AM
PWong's Avatar
It's to detect the presence of the battery.
Old 04-20-2015, 08:14 AM
It is NOT a pressure sensor
Quick Reply: switch in battery box
