ATTN: 200,000 Plus Mile Engines - All Generations
If you have a Cummins with over 200,000 miles, please post the following:
1. Year of truck
2. Current Mileage
3. Mechanical Repairs to engine only if any?(Exclude overhaul/rebuilds please)
4. Truck used for?
Lets keep this thread on target. No performance upgrade postings please. Trying to find out how many miles on the original engine people have and repairs if any. I will start things off.
1. 2005
2. 248,868 miles
3. A. Replaced the #4 Fuel injector tube line(Prone to going out)
B. Replacing Rear and Front Seals(as of writing)
C. Oil Pan Gasket(as of writing)
D. New Rear Seal Housing(Not needed, but by choice)
4. Long Haul hotshot
These engines are loyal!
1. Year of truck
2. Current Mileage
4. Truck used for?
1. 2005
2. 248,868 miles
03 with 285k
Only repairs have been rear main and cam seal and 1 CP3
Used for hot shot first 240k miles (first 2 yrs of her life!!!)
Used for daily commute to work now.
As for a stock motor I don't think you will find anything better than a Cummins!
2005 2500 2wd 230 k
used to pull gooseneck daily
idler pulley replaced
no other repairs
no other repairs
'03
~215k miles
#1 Stick @ ~98.5k miles (Warranted)
All sticks to F1, putting them back in today along with new #4 injector fuel line (PM)
ummmmmmm
ahhhhhhhhhh
ehhhhhhhhhh
Replaced clutch pedal rubber pad . . . oh, wait, never mind, not engine related
Will be replacing a couple valve cover bolts that were a bear getting out this round.
Daily Driver with a few 10k mile trips hauling my 5th wheel Fox, as far as Inuvik, NT.
Back to morning brew. . .
~215k miles
ummmmmmm
ahhhhhhhhhh
ehhhhhhhhhh
Seems you guys are having good luck overall with the exception of a few things! Keep them post coming. I know there are a lot of cummins engines out there with a ton of miles. You 1st and 2nd Gen guys jump in also.
2004.5
203,000
Lift pump replaced @ approx 65,000 under warranty no other repairs,water pump @ 180,000
Used to pull gooseneck several times a week,to pull 5th wheel seasonally,and daily driver.
Only other repair is a left front u joint
still running stock clutch and injectors
Just finnished a trip to Billings and back with 16 foot stock trailer and 2 horses and averaged a little over 15 mpg!Very happy with this truck.
203,000
263,000 miles
Head gasket at 186,000 miles. Slight coolant seepage to outside on right front.
2 stock lift pumps finally upgraded to Fass DDRP
Used as daily driver, tow vehicle for my Titanium 5'er and Key West Boat.
Super reliable....never let me down!!
590.000 miles on mine. 2007 5.9 cummins.
Routine maintence insues. Many tires.
Engine....... 406,000 injectors replaced
Water pump around 560,000.
Alternator around 560,000.
Power Steering pump last month.
Transmission 147,000 tranny replaced.
I have the entire maintenance on computer file.
Truck is used commercially to haul rv's.
I'll go ahead and chime in for my neighbor up the street:
2004.5
over 500k
I know he's had to replace the 6sp but that's not engine related
As far as the engine is concerned I believe a couple injectors and a CP3 have been replaced. We used to haul together. Other than that it's still rolling on!
His previous truck:
2000
497k when it got totalled.
Injectors, 1 injector line, and several vp44's.
2004.5
over 500k
His previous truck:
2000
Replaced the injectors because they were having issues at idle. It was a bit rough, but no problems when running or towing.
I doubt cummins will buy it back.
I know of some over 1.7 million.
2004.5
over 500k
His previous truck:
2000
2004.5
over 500k
His previous truck:
2000
The guys with 1.7 million. Are they 5.9's? If so, did they overhaul them yet?
