Anybody running a 325/65R18 on a leveled truck?
Old May 15, 2006 | 04:42 PM
ShawnQ's Avatar
I am getting new tires/wheels in the next few days, and can't decide between a 325/65R18 or a 325/60R18 Nitto Terra Grappler AT.
The truck has a leveling kit on it and is otherwise stock.
The wheel I am going with is a 18x8.5 with a +25 offset.
Here's the sizes of the tires in question:
325/60R18:
32.99"x12.83", 7.5" sidewall height, 3000lbs@65psi load rating, 630revs/mile
325/65R18:
34.88"x12.99", 8.44" sidewall height, 3195lbs@50psi load rating, 596revs/mile
Compare that to the typical 315/70R17 H2 take-offs:
34.5"x12.0", 8.75" sidewall height, 3195lbs@50psi load rating, 601 revs/mile
Which Nitto tire should I go with, and why? I am going with an 18" wheel, so the BFG's are out of the question.
Will the 325/65 be too large to fit, even with the narrow and properly offset wheel? I'm going to see if they will test fit one first, hopefully they will.
Thanks
SQ
Old May 15, 2006 | 08:20 PM
KevinH78's Avatar
Bump for this thread as I am searching like a mad man trying to find pics of a leveled truck with this size tire on it.
Old May 15, 2006 | 08:33 PM
Jmac's Avatar
Depends, If your going for the look, go with the larger tire. You might have to trim the plastic off the front and back of the front wheel wells by about an inch. If your going for a little better than stock but keep performanc and mileage go with the smaller tire. I sometimes wish I had gone with the terra grappler A/T 33.2" diam. with a leveling kit. Don't forget to have d/c reset your speedometer, truck drives/shifts better when it's set right.
Jamie
Old May 16, 2006 | 01:18 PM
ShawnQ's Avatar
Well, I got them.
325/65R18 Nitto Terra Grapplers mounted on 18x8.5 8-165 +25mm offset
Looks great, all for under $2k with full replacement warranty and lifetime rotate/balance on tires.
Will post pics later.
SQ
Old May 16, 2006 | 01:54 PM
ShawnQ's Avatar
Crappy Pics, but it's all I have for now...
325/60R18 Nitto Terra Grapplers
18"x8.5" +25mm offset MB Motoring Gunner 8's
No rubbing at all, even fully locked and climbing a curb.
SQ
Old May 16, 2006 | 06:51 PM
MegaRam's Avatar
SQ,
The truck looks Sweet jacked on those...
Old May 16, 2006 | 10:48 PM
VikingDiesel's Avatar
looks good, but dont really see a big difference from the 315/70/17
checkster
Apr 27, 2007 11:58 AM
checkster
Mar 14, 2007 11:12 AM
ShawnQ
14
Aug 3, 2006 05:40 PM
ShawnQ
May 30, 2006 09:48 AM
97CTD
Feb 24, 2003 05:00 PM
