Any Regrets w/315's on OEM Rims?
Old 09-17-2017, 03:45 PM
xxwildbillxx's Avatar
Question Any Regrets w/315's on OEM Rims?
Anyone had issues or regrets running 315's on stock 3rd Gen steel rims?
Old 09-18-2017, 08:11 AM
Mexstan's Avatar
I have been using them for many years with no problems. The engine RPM's drop considerably at cruise. The only minor problem I had was that the tires would rub slightly on the control arms at full lock. I fixed this by adding a small spacer on the steering lock each side. This spacer is small enough that I have not noticed any difference in turning radius.
Old 09-18-2017, 04:51 PM
Danderson's Avatar
I've got 35's on stock alloys. Zero rub anywhere.
You're referring to the ST steel wheels or the chrome clad steelies?
I lost 1 mpg going from 285-75-17 to 35-12.50-17's.
Old 09-19-2017, 01:05 AM
Administrator/Jarhead
madhat's Avatar
I had them for a while, BFG M/Ts. They rubbed pretty good, I just learned to drive around it. Filled out the wheel well really nice.
I probably wouldn't do it again, but they were good to go while I had them.
Old 09-19-2017, 08:12 PM
Mexstan's Avatar
Was out today in my truck and took note of the engine RPM's with my 315 tires. Just in case anybody is interested here is what I see;
60 mph = 1650 rpm
70 mph = 1900 rpm
80 mph = 2200 rpm.
Old 09-30-2017, 05:34 PM
Desert Dually's Avatar
Wink no issues whatsoever
been running the 315's on my 4x4 DRW almost since day one, so about ten yrs now, on the stock steel rims that came on my truck when new. Haven't had any issues with rubbing when steering is at full lock, so I'm unsure how others are reporting this problem unless they have a 2WD?
As somebody else mentioned, your RPM's are significantly lower than with the stock sized tires. I haven't noticed any issues with moving big loads either, although I rarely tow anything over twelve thousand lbs.
The increased footprint and wider stance gives heaps of benefits as far as traction is concerned.
bemhoff
17
07-05-2010 09:49 AM
flyingd
06-14-2010 01:58 PM
RDM16CTD
06-06-2010 11:20 PM
dslpwr81
04-21-2008 08:44 PM
tschwab
40
11-19-2004 07:11 PM
Quick Reply: Any Regrets w/315's on OEM Rims?
