AC performance mod
#46
i picked up the stuff to do my 6.7 last night. i got 2 ball valves, 2 brass t's, some hose clamps and an extra length of radiator hose. i think i am going to cut both lines, install valves and t's then run the extra piece of hose between the t's. that way i can shut off coolant to the intake and return lines of the heater core, but still keep it flowing through the turbo. i'll do the work tonight. my truck was in the shop yesterday to have them look at the a/c and do the latest flash. they said it was 1/2 pound low on freon. no leaks were found, so it must have come from the factory low. i'll let you know how the mod goes with the 6.7. the south texas sun has been taking the life out of the a/c in the afternoons lately. hope it works well.
#47
Here is a 12v electronic 3 way valve... with 2 of these you could automaticly shut of circulation to the heater core and open up a recirculation flow back to the engine... Expensive.... but a cool tech fix none the less!!!
Now just see if they will ship overseas or if they have them in the USA...
http://www.baytree.co.uk/products/20P_3way.html
Technical Specification:
Working Voltage: DC5V/DC12V
Working Current: 85 ±10mA
Static Current: 10±5mA
Input Power: max 3W
Working Pressure: 1.0Mpa
Actuator Rotation: 90 degree DC Motor
Rotation Direction: double acting
Operating Time: 5 seconds
Operating Temperature Range: -20 to +99 centigrade
Humidity Range: <95%
Manual Override: available
Body: brass or stainless steel
Enclosure: IP67
Actuator: heatproof ABS
Ball: brass or stainless steel - "L" or "T" type
Stem: brass or stainless steel
Sealing: PTFE, silicon rubber ball seat, EPDM and NBR stem seat, NBR o-rings
Please note that all BSP threads are parallel. Taper thread is available to special order.
Input Power: max 3W
Enclosure: IP67
#48
Jim O
#50
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
went to the dealership and showed my service adviser. He thought it was a cool mod and was curious to see the temps.
82 Degrees out
AC on high recirc
in their parking lot no moving
It settled at this temp and got there in a hurry. We had like 5 guys over there looking at it and thought it was cool. Will get some more temp readings when it gets hotter and on the move.
82 Degrees out
AC on high recirc
#51
82 Degrees out
AC on high recirc
82 Degrees out
AC on high recirc
#54
#55
got it all in tonight. took longer than expected. having to do the extra line to allow for the turbo, and the tight space took added time. i'll let you know how it works tomorrow in the heat of the day. i'll try to get some pics of the set up.the intake line is so **** tight, i am not sure i can even get a picture of it. the return has a lot more room. it needs to sit overnight anyway to cool down. it sat for several hours this afternoon, thinking it would cool down enough to get in there and work on, but it was still really hot, so i waited until this evening to tackle it. i have my fingers crossed that this works well. i'll let you know.
#56
Semis have been doing this for years, some are cable that move the valve, or use the air system. The valve only has to go on one line, usually its the pressure side.
#60
like stated above. will have those numbers soon. my truck is at the dealer getting a tie rod replaced, the boot is torn. i can call my tech and have him get those numbers for me while he is working on it. it was his dirty aresd fingers in the picture above! LOL
