2005 Ram 2500 4X4 electrical issues
I have a 2005 Ram 2500 SLT 4X4 regular cab 5.9 Cummins 610. The front hubs started grinding last winter. So the truck has sat for the majority of 2015 other than starting it now and then and a few trips around the block. I was planning on rbuilding the front end when I replaced the hubs (ball joints, U-joints, shocks, steering components, etc) So after finally buying all of the parts and rebuilding the entire front end, all new brakes on all 4 wheels, and new batteries..now I have an electrical issue that I can't figure out. When I turn headlights on, the left low beam and right fog light come on. When I turn on high beams, right headlight comes on and left foglight. Parking lights come on at all 4 corners but only the right rear brake light and turn signal work. When hazards are on, only right rear illuminates. I went thru and replaced all headlights, fog lights and turn signals. Same results. I looked at all the wiring harnesses I can find. I do not see any evidence of rodents chewing on wires. Any suggestions?
Should be able to see it from the left front wheel well.
Try cleaning the multifunction switch (See sticky section in this section). I that doesn't fix it up, then the IPM. See may rant/info in this thread:
https://www.dieseltruckresource.com/...issues-324940/
Chay
Chay
Donmacky
Jul 7, 2014 05:50 PM
Donmacky
Feb 1, 2014 06:07 PM
marksblaster
Oct 27, 2012 11:26 AM
Beaversprings
Aug 16, 2005 09:55 PM
