06 Drivers mirror glass fell out
Admin Team Leader
So early this morning I am backing my 35ft boat trailer uphill and into a door that has 3" of clearance on each side of the boat, behind my mile long Mega Cab in the rain, and trying to rotate it in because there is not enough room to get lined up straight......when just as I need the mirror the most it simply falls off This by the way was the ONLY mirror I could see out of because the truck was turned enough so i could not see the passenger side, but not enough to be able to turn my head far enough to see backwards
Anybody else been this lucky?
Hard to fix in the downpour but I managed to get it on well enough that I could duck real low and sit with my head almost on the steering wheel and almost see if I was destroying my boat
I now have it back together,(quit raining) amazing that it simply slides downward (when in tow position) and is held fast by 3 VERY flimsy spring clips....I am surprised it doesn't just fall off every single time you shut the door.
Just curious if I am the only one with this great lucky streak today?
It has not happened to me, but seldom am I towing something where I need my mirrors flipped up in the tow position.
Seems like there was a thread about this many moons ago.....
Admin Team Leader
I should note that my mirror was not in the tow position when it fell out....having now seen the design I can't help but wonder what the Engineers were smoking when they designed it
Admin Team Leader
I used the factory service manual which shows to put mirror in tow position to slide the mirror on over the 4 dog ears then the 3 flimsy springs hold the mirror in place. You have to press on the center of the mirror to get all 4 to slide together.
The problem is the 3 springs are so weak I can see no reason why this won't fall off again simply by closing the door a tad too hard if the mirror is not in the tow position.
As a Gunsmith I have access to all kinds of spring steel here and when I have the time I am going to see about modifying the unit with some stronger springs.
My truck although being a 06 it only has 36,000 easy miles on it, I am surprised the mirror set up is so weak. I want to note that if you leave your mirrors in the tow position they would have to jump up to dislodge from the mount and I can't see that happening on highway miles.
I've been watching my mirror vibrate pretty good at highway speed, especially in heavy cross & headwinds. When it falls off, I'll think of you Lary
You should see about upgrading to the new fangled mirrors that fit the 3rd gens and have the blinker light built in. Some aftermarket company was suppose to be coming out with those. Probably cost an arm and legg too
DTR Detective
55372200AA
That's the pn for the newer cheaper mopar hood shocks that fit the 3rd gens. Put them on my truck a couple months ago.
