06 2500 Daytime Running Lights U.S. import?
Old Feb 18, 2008 | 10:07 PM
TravisP30's Avatar
Question 06 2500 Daytime Running Lights U.S. import?
Hi, I've just bought a 06 2500 quad cab from the U.S. and will be bringing it into Canada. The laws in Canada require the DRL to work. I was told that it is just a simple option setting with the computer. I thought I would maybe just get it done at a dodge dealer close to the Canadian boarder because they move a lot of trucks into Canada. I phoned on dealer on the U.S. side and asked them if he could do it. He told me yes but the truck has to have the proper module in it. Its not just a computer setting. I already bought the truck and am going to pick it up in a few weeks. He told me if the truck doesn't have the proper module in it. I would have to get it done in Canada, and I'm guessing with a big price tag. Has anyone incountered this before. I'm kind of stressed out because I was lead to believe it was just a programing change and not parts to be added in. It seems like the 06 and newer have a different computer in them, from what I seen on the forums. Can someone please help me clear this up before I get the truck. I worried about a big bill attached to it, to get the DRL turn on to meet Canadian laws. Thanks for any help.
Old Feb 18, 2008 | 10:17 PM
worldindustries's Avatar
Someone can correct me if I'm wrong but I have been trying to get my dtl turned off but have been having no luck. These trucks run on a can-bus system, if I wanted to get my lights turned off i would have to have the country code changed to us then I could change the options like drl and fogs on with brights , for you to get them turned on all they would have to do is turn them on with star scan, thats what I have read here with some Americans who wanted them on for safety, worst case they should be able to switch you to the cdn country code then they will be on for sure
but they (my dealer) are not too excited to change codes because of warranty work I hope this was some what helpful and not just a
Old Feb 18, 2008 | 10:45 PM
mini14's Avatar
owners manuel i think has some info on this otherwize goto the standerd ignition web site, they make or distribute drl modules u can order them from napa i think around $35.00 and u wont need to go to the dealer for this.
http://www.standardbrand.com/web_app...trSearch=DRL-1
Old Feb 18, 2008 | 11:05 PM
Wv7o's Avatar
I had the DRL's turned off on my truck, A USA truck can have them turned on or off without changing the country code, it takes about 5 min for the dealer to enable or disable.
Old Feb 18, 2008 | 11:20 PM
Festus's Avatar
I tried with mine as well. Same reason from the tech that it couldn't be done - not without change of country code.
Old Feb 19, 2008 | 02:23 AM
Hounddog's Avatar
No module needed.Use the SEARCH function on this site.Lots of DRL info.
Old Feb 19, 2008 | 03:10 PM
chy46's Avatar
running lights
Had mine turned on at dealer for $35 ( US Truck in to Canada )
Old Feb 21, 2008 | 01:26 PM
spider_1954's Avatar
I turned mine on using the triple dog bully dog programmer
BuckyKatt
Feb 8, 2013 01:12 PM
getrdun
Nov 26, 2008 11:46 AM
canucktrucks
Apr 15, 2004 09:38 PM
blownbanana
30
Mar 28, 2004 12:41 PM
fitzer
Jan 18, 2003 01:11 AM
