-   3rd Generation Ram - Non Drivetrain - All Years (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/)
-   -   03 CTD HO Fuel capacity...in gallons? (please) (https://www.dieseltruckresource.com/forums/3rd-generation-ram-non-drivetrain-all-years-101/03-ctd-ho-fuel-capacity-gallons-please-23143/)
Hummin Cummins Jan 26, 2003 12:12 PM
Just wondering what the capacity (gallons) the fuel tank is?
Casey Balvert Jan 26, 2003 12:21 PM
Re:03 CTD HO Fuel capacity...in gallons? (please)
34 is the tank capacity. The actual usable fuel will be something less than that.<br><br>Casey
KenR Jan 26, 2003 12:33 PM
[quote author=balvert link=board=17;threadid=10130;start=0#96748 date=1043605310]<br>34 is the tank capacity. The actual usable fuel will be something less than that.<br><br>Casey<br>[/quote]<br><br>What does that mean about the actual usable fuel mean?????<br><br>Thanks
LinearX Jan 26, 2003 01:28 PM
[quote author=KenR link=board=17;threadid=10130;start=0#96752 date=1043606006]<br>[quote author=balvert link=board=17;threadid=10130;start=0#96748 date=1043605310]<br>34 is the tank capacity. The actual usable fuel will be something less than that.<br><br>Casey<br>[/quote]<br><br>What does that mean about the actual usable fuel mean?????<br><br>Thanks<br>[/quote]<br><br>Basically, that means that when you run the truck as close to empty as you can without actually the engine dying, you won't be able to put 34 gallons of fuel back in the truck. I've run mine as close to empty as I dare, and I only got 27.xx gallons back in the tank.
FiverBob Jan 26, 2003 09:56 PM
<br><br>Basically, that means that when you run the truck as close to empty as you can without actually the engine dying, you won't be able to put 34 gallons of fuel back in the truck. I've run mine as close to empty as I dare, and I only got 27.xx gallons back in the tank.<br>
<br><br>I've run down to 31.3. :P :P<br><br>BraveBob (or should it be StupidBob??)
ffemt1271 Jan 26, 2003 10:02 PM
they are 34 gallon tanks but when on &quot;e&quot; it will take 28 gallons--it's like that so the contaminants in diesel can settle to the botton of the tank and not be picked up-kinda gives you a &quot;reserve&quot; also---i asked the same question on here a while back and that is the answer i was given
DF5152 Jan 26, 2003 10:42 PM
is that for the short bed and long bed? Does th pickup go all the way to the bottom of the tanks or is it just the guage calibration?
Casey Balvert Jan 27, 2003 05:03 AM
That is the long WB capacity. The pickup goes close to the bottom but not all the way. Also the pickup is close to the middle of the tank so of the truck is slightly nose up or down when you are running, some fuel will stay in the ends of the tank leaving 4 to 6 gallons unavailable. Just consider it a 28 gallon tank for all intents and purposes. That is just the way it is.<br><br>Fiver Bob, you don't really want me to answer that question, do you? ;D
Green Giant Jan 27, 2003 11:04 AM
35 gallons for the 8' bed, 34 for the 6'<br>I have put in 33.8 gallons with the low fuel light on for awhile :o .<br>Jeff
pappyman Jan 27, 2003 11:18 AM
I have run outta fuel hittin the off ramp to the fuel stop...coasted into the station and filled up...took 31.5 gals...dont try this at home kiddy's Iam a trained pro (at doing stupid things) ::)
