'03 Climate Control Problem
'03 Laramie Trim w/ slide temp selectors
I have the dual climate zone control, and suddenly my left side blows quite a lot cooler than the right side when asking for heat (both temp slide controls set to same spot).
Even set all-hot for the left side, the air is cooler.
Is this likely a blend door problem or a controller problem?
Any hints welcome-
Bob
Any hints welcome-
Bob
Could be either of the problems that you mentioned, but betcha that you are just low in freon.
Not to steal anyone's thunder here, but I have a similar question.
No matter where I set the air direction, I can only get air out of the dash vents, no place else. the recirculate works only part time. any help?
Since when using heat only (not defrost that runs the A/C compressor), (i.e., trying to create positive BTUs to heat the truck's interior), I am unaware that any system involving freon is involved?
Possibly my fault for not mentioning that heat was the objective function I was asking about, but where I live in Washington State, staying DRY and staying WARM are the goals this time of year. It has rained 43 of the last 45 days here, so scratch 100% in category 1 (staying dry), and it's recently cooled off and is snowing, so I am attempting number 2 at least.
For the first time, I am forced to leave my truck outside 24/7, and it is now completely green (it is a white truck) from algae growing on the paint.
Right. If this problem is only for hear, then forget what I said about the freon. There are almost endless old threads on this site about blend door problems. Have you done a search?
On my truck I found that to switch the circulation, that the fan needs to be at the lowest setting or else it will not switch.
I was wondering out loud if the temp sensors and computer function (that run the blend doors) are equally suspect to the blend doors themselves.
I drove the truck extensively today and the temp from each side was quite the same, so I am guessing that the sensors and computer rarely become mis-calibrated day to day, so I suspect that it IS INDEED the blend door mechanical functions at blame, and will now concentrate on them.
Up until today, it was a crap-shoot which was the cause, I guess. I will do more specific searches to diagnose what may be sticking at times.
Hi did you find out what was wrong? I'm having the same problem.
SolarYellow05
06-22-2006 04:55 PM
grizzly660fan
01-02-2004 10:02 AM
BamBam
05-10-2003 08:50 PM
