Smarty and Edge insight or H&S mini maxx?
I am going to do the deletes here in the very near future and the thought i have rolling around in my head is this: If i were to run a smarty jr and an edge insight would i be able to monitor any more or less engine parameters than if i ran a mini maxx? I'm not looking for big pwer gains (yet) and know that the mini maxx and Jr will both acheive my delete goals very well.
i took the advice of members of this forum and went with Smarty Jr. and Edge Insight w/egt probe. i am very happy with this set up. Good Luck, Happy Thanksgiving.
I run a Smarty and have been looking at this also, which Insight is recomended?
You get about the same monitoring, but the new CS and CTS insights will be able to monitor just about any pressure or temps you want in the near future (i.e. fuel pressure, oil temp, diff temp, oil pressure, etc).. They will cost extra, but will be a nice package.
I am looking at a CTS to put in my truck for additional gauges and OBDII readout. |
As a former EJA owner, I wouldnt go back to a set of digital gauges. I like the analog gauges (other than aesthetic preference), and for one pesky reason.
If you wear polarized sunglasses forget seeing the display. Not sure if this applies to the CS or CTS, but the old displays became unreadable. |
(Post 2906994)
If you wear polarized sunglasses forget seeing the display. Not sure if this applies to the CS or CTS, but the old displays became unreadable. I do prefer analog over digital thou! But I think you have have the analog look on the CTS/CS. I will be keeping my analog boost, EGT, DP, fuel pressure.. But would like the CTS for IAT, rail pressure, post-pyro EGT, Turbo timer, oil pressure, trans temp, diff temp, oil temp, etc.. I talked with Edge yesterday the the accessories (other than pyro) and turbo timer are due for release in about a month. |
I'll have to try the polarized glasses with my mini maxx and see if it dissapears or not, i know my satellite radio suffers from that problem
