3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Question About Proper Sequence of Deletes and Smarty Install
Old Mar 11, 2011 | 11:51 AM
AggieRob93's Avatar
Question Question About Proper Sequence of Deletes and Smarty Install
Have EGR/Cooler/Throttle Valve/DPF deletes. Do these all happen before the Smarty (S-67 ME) gets loaded into the ECM? I ask because I've seen a retail website for the Smarty say the following:
"NOTE: When deleting the DPF with a Smarty tuner, the Smarty must be installed 1st on the truck!!!"
Is this correct?
Old Mar 11, 2011 | 12:32 PM
Lil Dog's Avatar
It is correct if you try and start the engine with those things removed. Otherwise, it doesn't matter so long as the software is loaded before you start the engine.
Old Mar 14, 2011 | 06:48 PM
Blake Clark's Avatar
I always do all of the hardware work, then load the Smarty for its first deleted crank.
Old Mar 14, 2011 | 07:48 PM
mikeshauling's Avatar
I loaded the smarty first, just to make sure it loaded right. I would hate to think that i just spent the time to delete everything and then have an issue that would leave me without a truck a day or so until i got it worked out....or worse yet, i would have to put it all back on !
Old Mar 15, 2011 | 11:22 AM
redruM Hauler's Avatar
mee too
thebeas06
Feb 5, 2008 10:08 AM
Ghost Ram
31
May 18, 2007 08:56 PM
fordsux8269
Jan 2, 2006 01:25 PM
