Preform Service 09 6.7
I have an 09 6.7 that has the preform service message on message center.
This comes on at 65000 mile for the CCV filter to be changed. How do I reset the message after changing filter?:cool: |
Try this:
1. With your doors closed,turn the ignition switch to the ON position (Do not start engine). 2. Press and release the brake pedal two times. 3. Fully depress the accelerator pedal slowly two times within 10 seconds. 4. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service” indicator did not reset. If necessary repeat this procedure. |
