Question about timing
After installing Mini Maxx w/trans tune and fully deleting my truck I have a rattling sound when accelerating. Almost sounds like detonation on older gas engine. Buddy tells me I should set timing to 2 and run tow power level to cure the rattling.
What do you all think? Truck is a 09 with auto trans and I only run stock power setting because I don't want to damage my trans or blow head gasket. I am happy with power at stock setting, more concerned about trucks components lasting as long as possible, and mpg.
Any reccomendations on what my settings should be?
I have same truck as you. 2009 with 6.7 & 68RFE. I went with the defaults thru the install of the min max, but I run the tow tune all the time. My mechanic said it wouldn't hurt it, and so far EGT's & trans temps confirm this. Diesel's do rattle, so can't help you there.
Thanks everyone. Set timing to 2, and running tow. Rattling gone with more power. Just wanted to make sure I wasn't going to prematurely wear any components out doing this.
Honkylips
10-15-2007 07:07 AM
GR40RCapri
06-25-2006 12:53 AM
West Coast
03-26-2006 11:09 AM
RonP
02-24-2006 02:12 PM
