Instead of dpf delete
I went to my local dealer and was talking to the diesel tech about the dpf delete and he told me that instead of taking the dpf off the truck and having the cel light come on he said to take a 7/8 inch auger bit and drill a hole down thru it he also said not to go any bigger than the 7/8 inch bit because it will then set the cel light with a code but that the 7/8 inch hole will let it breath better.
From: This Nazi state of California 2nd home Gilbert AZ under God
That will not work. You will soot up the rest and have a single 7/8 hole for your exhaust to flow thru restriction. It will probably stop running after it plugs up
I wouldn't count on saying bye to those uninion contracts because from what I'm reading Obama is going to guarantee their benefits like he is guaranting the warranties.
