HELP!..NEED Clarification on SMARTY s67
What SW levels should you be running if the truck just has deleted DPF, EGR etc?
The way I understand it... is if you are running with just deletes (stock) you should be running the odd number SW levels and if you have another type of tunner installed you should be running the even numbers.
what would happen if you ran even numbers with out stacking?
With what I have...which numbers should I run?
The only difference between the even numbers and the odd numbers is the addition of timing. Since you don't appear to have any other boxes installed on the truck you'll want to run the odd numbers as the additional timing has the added benefit of increased fuel economy and lower EGT's. Also, you can run an even number and add timing to it via the Revo options if you prefer.
Stacking the Smarty with boxes such as an Edge, or MP8 isn't recommended and is usually frowned upon. Stacking really isn't necessary as the Smarty can push a slightly modified truck to the limits by itself.
You'll want to make sure you have the lastest software installed on your Smarty which is currently 19ME as software prior to 18ME have excessive timing which could lead to premature head gasket failure and excessive rattle.
Good Luck!
Good Luck!
jthorpe
13
May 13, 2011 07:51 PM
cowpunch
52
Apr 23, 2009 06:51 PM
jsdavis84
Feb 12, 2009 11:03 AM
rahtok
Mar 27, 2008 09:41 AM
