H&S Updates
this morning my neighbor asked me to get information on his Minnimax on his 5500 Ram that goes off when he hist a bump in the road but comes back on when it wants to.
I have looked for some trouble shooting but nothing comes up. Can anybody help him?
Labarn
Labarn
Well guys, it's been awhile since contributing to (or detracting from) the forum so here goes:
Labarn, I'm not sure what all has been checked but a couple possibilities come to mind; 1) The MiniMax cable is loose at either the OBD2 port or on the back of the Tuner. Unplug and reattach to be sure the connections are good. Hopefully it's not an issue with the cable itself, OBD2 port or power supply to the OBD2 plug.
2) The micro-SD card is not fully seated or is not making good contact with the unit. (less likely but possible).
Good luck & I hope he finds the problem.
just a guess but it might be a way to get you to buy the MCC codes and start writing your own stuff in search of more, I doubt that they found what they were looking for in terms of mileage and power gains and quit
the best mileage back on 6.7.26....... more stuff to be had with the newer tunes and firmware updates so I may reload 6.7.26 on the truck and then reload the 6.7.50 on the tuner and get all the features of the new stuff at the expense of a few tweaks I didn't use anyway
Since H&S is off the grid, I would have to rely on some of the more forward looking members of the Forum for downloads, unless there are other sources which I have been unable to find.
Any opinions or help will be greatly appreciated.
I would also like a list of tunes, I got my mini maxx awhile ago but wasn't able to afford a new clutch so I kept it on stock. Now I have the new clutch so I have been doing a lot more testing....but my brake/ABS light comes on every once in awhile. I heard the newer versions solved this problem. Any help would be great, thanks.
XRT Pro Updates
Newbe here, but been driving my 2009 since new.
Does anyone have a personal repository somewhere of XRT Pro updates?
Also, I'd like to get a code for the trans tuning.
To be quite honest, I haven't meddled around much in my vehicle in 5 years, except to change the batteries, and the water pump.
But I'll be on here more often, as she is no longer a driveway ornament, and is my daily driver. Most of the time long haul.
ETS 76
09-14-2011 09:52 AM
kennymac131
04-19-2010 11:38 AM
Lary Ellis (Top)
01-21-2003 05:10 PM
