H & S tunning updates
I was thinking about down loading the hot **** 225 soft ware. Has anyone run this tune without any fuel upgrades. H & S dont without fuel system upgrades.
I have a sneak in suspicion that Cummn&Smokin takes a toll on the fuel because of the pressure differential between shifts. My Automatic keeps up fine until I hit about 100. My rail isn't plugged. Let us know how that 225 works out for you. I'm considering taking my XRT down to 60 and adding a juice w/ attitude. My uncle has a smarty and juice that work wonders together.
The Guru
Mine worked ok, couldn't tell much different power wise. Was smokier than normal stuff. Guess I should have recorded the rail pressure to see. Some guys add a rail shim for the relief, doubt you'll need to upgrade CP. Lots of guys running injectors, think 90HP is the limit of the stock CP.
As for the RFE68 being able to handle it, doubt not for long.
kennymac131
04-19-2010 11:38 AM
Ghost Ram
01-01-2008 05:59 PM
