Electronic Throttle control issues..need help.
My dad has an 07.5, 6.7, 2wd mega. Been trying to help him the last week or so get his truck running right. Did as much research as I could and everything lead to replacing the accelerator petal with the throttle position sensor on it. It would run like crap, stay under 50mph, and then would run ok some days etc, was off and on. The last bit the accelerator wasnt even responding. So put a new one on, cleaned up all the battery connections, recalibrated new one and cleared codes. Stayed running good for 1 day, thought it was fixed till just a bit ago he said was sputtering and ETC light on dash came on again.
Codes before we swapped new sensor
P2127 - Accelerator pedal position sensor number 2 circuit low
P2299 - brake pedal position and accelerator pedal position incompatible
P2122 - Accelerator pedal position sensor number 1 circuit low
p2121 - Accelerator pedal position sensor 1 performance
Dont know what the current codes are that were thrown just a bit ago. Hes going to get the batteries load tested tonight. I did read the sensors are sensitive to current provided. The battery cables and connections have never been replaced as well. I really dont want to be chasing this, and need some help in what to look at next. As soon as I know current codes I'll post them. Truck has 215k miles, and batteries are about 4 years old.
3 things happened before this all started, so dont know which one caused it.
cleared change oil minder on console by stepping on accelerator 3 times rapidly
washed out under the hood with simple green after changing oil
disconnected a big wire harness above the fuel filter (to change filter) that is mounted on the top of the firewall...put back together and truck wouldnt start, so I disconnected and reconnected and it started after that...not sure if something glitched in that harness etc. Its a big mess of wires coming together at the harness.
Sorry this was long but wanted to give as much info as I could to hopefully help my feedback. Thanks guys!
Cummins Guru
Did you use factory APP or did you use aftermarket? I would ohm check wiring to PCM to make sure wiring is not causing problem. I have had to replace APP 3 times before I found a good one. That is using factory parts also. The last one has been on for 6 months so far and hasn't failed yet. I'm feeling lucky so far. Never probe the PCM connector or you will spread it and cause a bigger problem. Only back probe with proper test probe. Or use a paper clip. But never probe on the connector side. If you already have then that can be your problem.
hyunsinsone
10-30-2008 07:48 AM
DodgeCowboy
16
12-20-2007 08:04 AM
MikeRP
12-12-2007 11:50 AM
fflarry
11-17-2007 04:11 PM
