Dual CP3 Detailed Instructions with Fleece Distribution Block !!
I just installed my Industrial Injection Dual CP3 Kit with Fleece Deluxe Distribution Block . The results are amazing ! This is a must install for guys looking to get the most power out of there 6.7 Cummins. Watch the video and Subscribe and hit the like button if you like my video ! Thanks Guys
Just saw this post and am curious about something. Can you please provide a technical explanation of how adding a second CP3 increases performance/power.
Here is how I see it. Adding a second pump will probably increase the flow or volume, but not the pressure. The injectors are designed to deliver a precise, set volume of diesel per pulse, so how will adding volume or even pressure increase performance? What am I missing?
So for now my dual CP3's make more Horse Power because they can feed the fuel injectors to the max and I have a Airdog 200gph lift pump so I'm sending enough fuel to the CP3's before I installed the duals I wasn't sending enough fuel to the CP3's .
Was wondering if you needed to install bigger injectors, so this now makes sense. 300% over? WOW, what is your expected fuel consumption after all those mods? 8 MPG?
I plan on rebuilding the engine soon with a D&J Enforcer engine and head so that I can have a reliable 2k horse power truck .
N8theGr8
0
May 2, 2009 02:23 PM
JSCumms2000
0
Apr 5, 2009 02:07 PM
jmmcdona
Dec 26, 2008 10:04 PM
joesixpack
0
Nov 27, 2008 11:16 PM
megacabrule
33
May 10, 2007 01:07 PM
