A couple of 6.7 questions.
I currently have a couple of upgrades in work for my 08 dodge. I am going to add a cold air intake, smarty, 5 inch tbe,smoke switch, all the guages (trans temp,egt,boost), and a boost fooler. All of this work will be done at Mid Atlantic Diesel Performance. Also, i will be putting on a adrenline 2.5 inch lift kit. My main questions really are:
1 Should I be installing something else other than these upgrades?
2 Am I making a good decision by getting my work done at M.A.D.P? Do they do good work?
3 Is the adrenline lift kit the best option within that price range?
I am new at this 6.7 diesel thing so ANY help/suggestions will help a bunch.
Thank You
Thank You
"California Style"
One thing that comes to mind is that you don't need any boost fooling with the Smarty. It all ready has it! I assume you'd be deleting other items like EGR, Cooler, TV, in the engine bay as well.
Sound like you have a good plan in mind. You wont regret it. I have no personal dealings with them, but have never heard anything negative.
Im with mega on this though, you shouldnt need a boost fooler with the set up you plan to run. I also recommend full deletes if possible.
Thank you all for your suggestions! I will take off the boost fooler and add something else to my list. What should I add to the list? EGR delete? or some other delete?
"California Style"
EGR Delete, EGR Cooler Delete, Trottle Valve Delete. That will get rid of the basic emmisions junk. Look into trans upgrades and programming for it if you want to put some power down though.
I think this is my problem now!! I have straight pipe exhuast and uploaded the ME tune to get ride of the regs however my egr is still plugged in on the intake horn. My truck smokes A LOT more then others tell me it should, so deff do ALL the deletes, egr and cooler. Plus with out the cooler it looks WAAAAYYYY cleaner
I there a website i can buy all of the deletes from? Will you still get some smoke with a smarty with the egr off? I have looked on purecummins.com and found the complete egr delete (cooler and egr), however cant find throttle delete. Anyone know of a good low price lift kit?
http://www.rockymountainsusp.com/
Like Joe said it will smoke some, but if you do want it to smoke more, I can help you with that too.
"California Style"
