B&W turnover ball and 5" exhaust
Got a 07.5 dually 4x4 and a b&w turnover ball. Wanting to put a 5" flo pro turbo back exhaust on but don't know if I have the clearance. I guess the issue isn't with the hitch but the Pacbrake airbag bracket.
Don't know about those airbags, but i have firestones, b&W hitch and 5" exhaust on mine all without any clearance issues. The only tight spot with my exhaust is the 51" long muffler rides close to the driveshaft, but hasn't touched it yet.
What that shield plate for? I would just use a hammer and put a dent in the exhaust if your worried. I usually just let my exhaust rattle on stuff adds to the effect
. The TBE 5in exhaust system is pretty big pipe. I had a TBE 5in on 02 off a few sets of twins turbos. No real power advantage vs. 4in exhaust, except its louder.
My spare tire rubs/bouces off my 02 exhaust and no I don't have a shield on that. Been that way for years and yes I do tow and drive the 02.
. The TBE 5in exhaust system is pretty big pipe. I had a TBE 5in on 02 off a few sets of twins turbos. No real power advantage vs. 4in exhaust, except its louder.My spare tire rubs/bouces off my 02 exhaust and no I don't have a shield on that. Been that way for years and yes I do tow and drive the 02.
It came with the airbag kit. I assume it's to keep the rubber bag from melting. 4" exhaust would be fine for me but the place I order my junk from has a good deal on a smarty sr./ 5" turbo back combo.
Thread derailment in progress.....
How do you like those airbags???
Im in a toss up right now between a set of bags or a set of Hellwig helper springs. Not sure which way I want to go.
Air bags deflate=noraml ride restored when not needed, plus you can adjust load and balance weight on front and rear axles some.
Unless you are over 700 hp 5 inch will gain you nothing imho. If you feel you must i would do some grinding on the bracket and some massaging of the pipe with a hammer if you need some clearance.
ddszero
May 18, 2010 11:10 AM
scoutman
13
Aug 12, 2008 10:59 AM
cummins dsl
Feb 21, 2008 03:53 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
tobyw
Jul 14, 2003 08:17 PM
