X2 ECT set point
Hey I tried looking for what the set point for cold engine pertection on the X2. I know the web site says that it will be changable or able too switch off via usb update. So is there a factory set point for ECT(engine coolant temp) before it starts adding power. Or is it turned off until updates become avalible?
just asking no specific reason just was wondering. Oh by the way Quad nice harnesses much of an improvement. |
I have my XZ2 set to a warmup temp of 160* before adding power but I did that through the Commander. Not sure if there is a warmup temp if you just have the box and no Commander.
guess nobody knows the answer.
According to Quad Tech support, the warm-up option will be available via usb sfwr. update in the near future, whats needed is the new harness and control pod. In the interim, you have the power settings and an additional ECT guage to check against the factory temp guage. By the way, if anyone is having problems with the control pod ECT reading, make sure the orange wire is set correctly in the 12-pin connector on the new wiring harness.
Yep got new everything. Just was curious if there was a setpoint 140-150 degrees from factory (Quad). Another reason for this question is when I replaced the old harness to new one. With the ECT pluged in it seems that it take abit before power is added. I notice it in the morning when its cold I can see the rail pressure is arround fact reading. When it gets arround 150 ish it starts kicking in.
Thats why I was asking this question. Or is this in my head. |
