will a 6.7 MP8 work on a 2003 5.9?
I was told by two people it would. Is this right?
I know the rail sensors are different, so it would take some modification to the plugs.
Not sure about the signal, thou.. Both are 0-5v senders, but the 6.7 runs more pressure. |
Plugs are different but you may be able to get the harness from TS is the box is the same.
Ok TS will have to answer my questions. i got the MP8 from a guy who had it on a 6.7. I put the MP8 on and the rail pressure harness on the MP8 was exactly the same as my rail sensor on the 5.9. But when I dial it in, nothing seems to change on my rail pressure. Im not sure if its compatiable but it matched right up to the plugs.
Originally Posted by SpeedyWS6
(Post 2800042)
How are you reading rail pressure?
I posted the same ? on the 6.7 forum said it won't work.
