Why wont both my tires spin if my truck has a limited slip??
It is really simple...so I guess I will have to make a "scientific" explanation.
Lets say a rig is crossed up in a ditch...left front and right rear touching...the other two in the air. To move the vehicle, it would take x amount of torque (taking into account elevation change, friction, etc.) applied to the two wheels.
If the diffs were open, the two wheels in the air would spin. If the diffs had LSD...the may or may not spin.
With either diff, if a "brake torque" greater than the required torque to move the vehicle is applied, then a drive (or engine) torque is applied greater than the resisting brake torque, viola...you have 4 tires turning the same speed. PERIOD.
Now, I'm not saying that brake modulation won't help some, but let's be realistic here. By pumping the brakes and giving it a ton of throttle you can usually get the tires with traction to break free and rotate maybe a 1/2 - 1 complete revolution. Saying all 4 tires will magically start spinning at the same speed is just plain false. Anyone who's been stuck in that same situation know's the truth. Anyone who 'wheels hard also knows that LSD's are completley useless when tires are off the ground.
Maybe that is too complicated for you to understand. Like I said...lockers save your brakes and prevent having to waste torque (brake torque) to achieve true 4 wheel drive.
Re-read what I wrote...ahhhhh.
I said WITH the brake pedal, I can FORCE all 4 tires to spin the same speed.
I did not say by themselves.
Wetspirit
It turns out that after all this time. After all the designing of differentials, the selling and installing. All the poor souls that got stuck. All the cost and debating. Well, it turns out all that was needed with an open diff was to step on the brake pedal! Wow! Why didn't I think of that?! Next time I'm rock crawling, or a wheel is hangng in the air I'll give that a try, if I can remember it. I love scientific solutions.
Wetspirit
Wetspirit
53 ******,
When I purchased my truck there was an extra charge for the "anti spin" diff marked clearly on the window sticker and build sheet. Nowhere did it say "limited slip".
I believe that they are two different things entirely, hence all the confusion.
Rick
Rick
Good phrase by the way!
Correct.
Point being:
If it does not say "anti spin.......$300.00" on the build sheet then you do not have a "limited slip".
It is a markable option on the J build trucks and standard equipment on the H build trucks. If you don't read every option on the list you could very easily get a truck that does not have the "anti spin" limited slip.
Rick
D - it certainly wasn't the semi-literate Socrates, but I don't recall either Plato or Aristotle getting credit for that nugget.... besides, anything they had to say was Greek - and Roman grammarians and Muslim scholars translated what little of their works survived centuries after their deaths.
It's merely one of the expressions from back in the day...
Blah blah blah blah blah
this thread sucks
and I have been to busy to look at my truck today.
I didn't ask the difference between lockers and limited slip so lets quit arguing about it.
this thread sucks
Correct.
Point being:
Rick
Point being:
Rick
the part that's disappointing is the 01 limited slip that every one "hates" was awesome IMHO If I stop at the bottom of my drive way with the 01 I could give it regular amount of go pedal and BOTH tires would lock up and drive me straight up the drive way.
I never had to milk it, Gas it or apply brakes to get it to work
I am going to get in trouble for this...
but,
JRussel, you are not the brightest light out there.
You are still arguing apples to oranges. Everything I said about getting four tires to spin is true. I wheel hard...and have been forced to do this before.
I am sorry if you disagree. So if I can prove it mathmatically...and in the real world, why do you argue?
I have still yet to say that a open or LSD diff as good as a locker. I have simpley described a method to make 4 wheels turn the same speed.
Email me to carry this on further not at the expense of other DTR members.
cquestad@ssproducts.com
Christian Questad, PE
Back on topic...I still wager the diff is empty if it is performing that poorly.
Back to the topic
but,
Back to the topic
